Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
I'm sorry but unless I download & fully research your particular board then
I'm only going to give you broad help.
JBOD is a "cool" search in google.
When you get the choice of raid to setup with your scsi drive or drives
(Yes, I know they aren't but you need to pretend or you'll get nowhere),
choose BSOD (bunch of ordinary disks)& that will get you something similar
to your old IDE arrangement.
You then need to go into boot order, select SCSI & then select which drive.
The biggest hurdle you need to overcome is to go to another comp first & get
that scsi driver onto a floppy ready for when you install your OS. Hit F6
when asked & then point to your floppy.
Somewhere along the line you get the choice to hit some keys to setup your
array. DO it & setup as JBOD.
You starting to get the picture?
Forget all previous preachings from the past.......... think diff & you'll
succeed.
"Gummy" <gumbatman@hotmail.com> wrote in message
news:11d3rgi9o9mu638@corp.supernews.com...
> Bruce,
> Thanks for the info but what is JBOD?
> I don't see any settings for SCSI in my BIOS.
> I really do appreciate the response to my posting but could you be a
> little
> clearer in your response. I don't have a RAID set up (at least I don't
> think
> I do).
> Thank you for the information.
> "BruceM" <bruce@@hotmail.com> wrote in message
> news:42d1e210$1@duster.adelaide.on.net...
>> You need to put your optical drives on the single IDE channel & then any
>> other ide HD's on what you will see as SCSI channels.
>> You need to set bios to boot from scsi & set your raid to JBOD.
>> I'm NOT going into details but giving you basic tools to look at.
>> I'm not even familiar with your board.
>> Don't even bother expecting the bootup screen to detect & show your
>> HD's.............. it won't.
>> news:11d3nfmr96kc676@corp.supernews.com...
>> > Hi Jan,
>> > I first tried changing the BIOS into "S-ATA & P-ATA" mode from SATA
>> > mode
>> > and
>> > that moved the SATA drive to the primary spot (not that it mattered).
>> > There
>> > still was no IDE recognition.
>> > I then tried removing the SATA drive, placing it in P-ATA mode with a
>> > HD
>> > and
>> > DVD on cable select and that found nothing.
>> > The other thing I noticed was that the CPU temperature is running at
> about
>> > 86C, which I think is way too high. Could that be having an effect or
>> > maybe
>> > symptomatic of something else?
>> > Thanks so much for the quick response and great answers.
>> > "Jan Alter" <bearpuf@verizon.net> wrote in message
>> > news:aRkAe.2142$Om4.315@trndny07...
>> >> Hi,
>> >> It seems that you're doing everything correctly. Have you tried
> cable
>> >> select? Jumper the both drives for CS and put the hdd on the end and
> the
>> > DVD
>> >> on the center connector. As a last resort have you checked the manual?
>> > Maybe
>> >> there is some esoteric setting that has to be adhered to with this
> board
>> >> because it has only one IDE channel.
>> >> Jan Alter
>> >> bearpuf@verizon.net
>> >> or
>> >> jalter@phila.k12.pa.us
>> >> news:11d3kle140rt96f@corp.supernews.com...
>> >> > Hello,
>> >> > I am building a new machine (something I've done before but not in a
>> >> > while)
>> >> > using an ASUS P5GPL motherboard. When I put my new Western Digital
>> >> > HD
>> >> > it
>> >> > recognizes it, but thinks it is the third primary IDE drive. That
> seems
>> > OK
>> >> > because I was able to format it and it boots correctly to that
>> >> > drive.
>> >> > Then I installed my DVD burner (Sony) and it is never found by the
>> >> > BIOS.
>> >> > There is only one IDE controller so I've tried many different
>> > combinations
>> >> > when the ones that should work didn't. This included changing the
>> >> > IDE
>> >> > cable,
>> >> > trying a CD burner and/or a regular IDE hard drive. I've tried
> changing
>> >> > the
>> >> > jumpers to make the burner (or HD) the slave, the master and placing
>> >> > the
>> >> > drives on different places on the IDE cable but nothing seems to
> work.
>> >> > I
>> >> > tried forcing the BIOS to tell it there was a CDROM on the IDE but
>> >> > it
>> > just
>> >> > gave me the error that there was no ATAPI compatible drive.
>> >> > Is there something wrong with my motherboard? Is there any way I can
>> > test
>> >> > this to make sure I'm not the problem?
>> >> > Thanks for the help.
>> >> > p.s. Sorry for the crosspost, I was reading the other one but meant
> to
>> >> > post
>> >> > here.
