want to rewire power supply
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I want to make a 17 volt dc power supply.
If i take an old at power supply and splice the 5 volt rail and 12 volt rail
in series, as if they were two batteries, would I have a working regulated
17 VDC supply?
TIA
mike
6 answers Last reply
More about want rewire power supply
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    rail
    > 17 VDC supply?
    No, because the ground (return) values are at the same potential.
    Considering your battery analogy, this is the equivalent of connecting both
    (-) terminals with the batteries in series, which will place a direct short
    across one battery.
    If you don't need much current, you should be able to use the potential
    between the (-12V) and (+5V) to get 17VDC. You'll need to keep within the
    ratings of your PSU, of course.
    Jon
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Jon, thanks for the head's up.
    What if I take the (-) from the 12V+ and use that for one side of the load,
    then connect the (+) from it to the (-) of the 5 volt and use the (+) of the
    5 volt for the other side of the load?
    Mike
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Mike Hollywood"
    load,
    the
    Mike, it is easier to follow the conversation if you quote the context you
    are replying to, then provide your content below this.
    That being said, no; as I stated before, the returns (grounds) for all
    connections out of your PSU are at the same potential. What you are calling
    the "(-) from the 12V+) is the same return as for the +5V. To provide 12V,
    you use two leads, one at 0V (the return, or ground), and one at 12V;
    likewise, to provide 5V, you use two leads; one at 0V and one at 5V; the
    *difference* between the two connections is the Volts you obtain.
    I would suggest you obtain a multimeter so you can measure the voltage
    difference yourself (along with other generally useful things)
    Jon
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    ok on the quote of original, I thought it was "cleaner" to not repeat what
    already was posted.
    ok on the measurements. Will do and let you know how I make out.
    mike
    ----- Original Message -----
    From: "Jon Danniken" <jonREMOVETHISdanniken@yahoo.com>
    Newsgroups: alt.comp.hardware.pc-homebuilt
    Sent: Tuesday, July 26, 2005 2:21 PM
    Subject: Re: want to rewire power supply
    > "Mike Hollywood"
    > load,
    > the
    > calling
    > 12V,
    > Jon
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <wNidnWBhT4r6-XvfRVn-iA@comcast.com>, Mike Hollywood says...
    > 17 VDC supply?
    No. A better idea would be to take -5V and +12V. That'll give you a
    potential difference of +17V which anything attached as follows would
    see as a 17V PSU.
    Connect the 0V rail of whatever you're wanting to power to the -5V and
    the +ve rail of whatever you're wanting to power to the +12V.
    Conor
    -You wanted an argument? Oh I'm sorry, but this is abuse. You want room
    K5, just along the corridor. Stupid git. (Monty Python)
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >>17 VDC supply?
    > see as a 17V PSU.
    There's no way to 'splice' the 12 and 5 in series anyway as they have the
    same ground.
    -5 and 12 will work, assuming nothing is ground referenced, but the current
    will be limited by the least of the two. In this case, the -5v.
Homebuilt Hardware Power Supplies Systems
