G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hello,
I was called yesterday to look at a Celeron 1.1 GHz computer I had
built several years ago. It wouldn't power on.
I took an extra power supply along and my external HD enclosure. First
I swapped out the power supply, but no change. I noticed that there
were no lights or sounds, except the CPU fan was spinning. Next I
removed the only PCI card--an ethernet adapter, but it made no
difference. Finally I disconnected CD-ROM, floppy, and both IDE HD's.
The system finally powered up! When I plugged the master IDE HD back
in, the system quit again.
I pulled the HD out of the computer and stuck it in my external HD
enclosure...connected it to another PC with USB connector...HD spun up,
and I could read and copy files.
So, my question is, why can the HD spin up in the external USB
enclosure, but prevents PC from powering up when connected internally?
Should I just forget why, and order a new HD?
Thanks in advance.
Bill
Hello,
Thanks in advance.
Bill
