Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Just bought a new laptop with dvdrw and after all attempt to burn anything
on a dvd-r disc is imposible. i did mange to burn a cd data disk. below is
the log file if any one can help thanks. or am i just a dummy?
Stephanie
1A23-9000-6030-2391-0264-0015
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll':
Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero API version: 6.6.0.15
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 15e
Recorder: <Slimtype DVDRW SOSW-852S>Version: PSX3 - HA 1 TA 0 -
6.6.0.15
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG MP0603H atapi Port 0 ID 0
DMA: On
CdRomPeripheral : Slimtype DVDRW SOSW-852S atapi Port 1 ID 0
DMA: On
=== CDRom-Device-Map ===
Slimtype DVDRW SOSW-852S D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1007MB (1031536kB)
Free physical memory: 710MB (727112kB)
Memory in use : 29 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
28.7.2005
NeroAPI
1:30:09 AM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
1:30:09 AM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
1:30:09 AM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
1:30:10 AM #4 Text 0 File Reader.cpp, Line 127
Reader running
1:30:10 AM #5 Text 0 File Writer.cpp, Line 122
Writer Slimtype DVDRW SOSW-852S running
1:30:10 AM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
1:30:10 AM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
1:30:10 AM #8 ISO9660GEN -11 File geniso.cpp, Line 3309
1:30:10 AM #9 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using DVD media
1:31:09 AM #10 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286351 (508:04.51, 4465MB)
1:31:09 AM #11 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO
1:31:09 AM #12 Text 0 File DlgWaitCD.cpp, Line 2457
Recorder: Slimtype DVDRW SOSW-852S, Media type: DVD-R
Disc Manufacturer: MJC ME -
Disc Application Code: 64, Disc Physical Code: 193
1:31:09 AM #13 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW,
DVD-R/RW, DVD+R DL.)
1:31:09 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286352 (2286352) = #2286352/508:4.52
relocatable, disc pos for caching/writing not required/ required, no
patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length
2286352 blocks [Slimtype DVDRW SOSW-852S]
1:31:09 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [Slimtype DVDRW SOSW-852S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0
4682448896, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286352 | lead-out | 1 | 0x41 | 0x00
1:31:09 AM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
1:31:10 AM #17 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
1:31:10 AM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
1:31:10 AM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2x (2,770 KB/s)
1:31:10 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos,
orig at #0): write at #0
1:31:10 AM #21 Text 0 File DVDR.cpp, Line 2340
Recording mode: Sequential Recording Mode
1:31:10 AM #22 Text 0 File Mmc.cpp, Line 21627
Set BUFE: SMART-BURN -> ON , Adapt writespeed to disc : ON
1:31:10 AM #23 Text 0 File DVDR.cpp, Line 2494
Start write address at LBA 0
DVD high compatibility mode: Yes
1:31:10 AM #24 Text 0 File Cdrdrv.cpp, Line 8821
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer
Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW,
DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h,
4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1:31:15 AM #25 SCSI -400 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03D70000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x27
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x27 0x00
1:31:15 AM #26 CDR -400 File Writer.cpp, Line 311
Unspecified target error
1:31:16 AM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
1:31:16 AM #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
1:31:16 AM #29 Text 0 File DVDR.cpp, Line 2732
EndDAO: Last written address was -1
1:31:16 AM #30 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2x (2,770 KB/s)
1:31:16 AM #31 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
1:31:16 AM #32 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs :
0 (Security Option)
Stephanie
Windows XP 5.1
IA32
WinAspi: -
6.6.0.15
DMA: On
DMA: On
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
28.7.2005
NeroAPI
Reader running
patch infos
DAO infos:
MCN: ""
Tracks 1 to 1:
4682448896, ISRC ""
DAO layout:
Type: recordable
DVD+R/+RW)
4193920 MB)
Sense Code: 0x27
Sense Qual: 0x00
Existing drivers:
Registry Keys:
0 (Security Option)
