Extend your power button
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I am going to attach my pc to my LCD screen in my kitchen, the PC
itself is in a laundry room next door. I am going to run the wireless
receiver for the KB/mouse into the kitchen. The only thing left is the
power, does anyone have any ideas on how to power this pc on and off
from the other room? I don't know if its possible to wire a separate
switch from the motherboard/AT power supply... Any ideas?
10 answers Last reply
More about extend power button
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    You can wire a second momentary contact, normally open switch, in
    parallel with the case power button Assuming this is an ATX motherboard.
    Just get something like a Switchcraft ED903.
    "http://jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&catalogId=10001&productId=297502"
    You could get fancier.
    Buy the X10 UM506 module ("http://www.x10.com/automation/um506_s.html")
    which is basically a set of isolated contacts that can be set for
    momentary or sustained closure. Connect these contacts to the header on
    the motherboard (set for momentary). Then use an X10 tranceiver module,
    with remote, to control the UM506. this setup would cost around $35.
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On 1 Aug 2005 12:38:22 -0700 As Androids Dreamed Of Electric Sheep and
    Send the,"Missus" to press the button :D
    Free Windows/PC help,
    http://www.geocities.com/sheppola/trouble.html
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Shep©" <nospam@nospam.com> wrote in message
    news:avbte11f4ns99vscp943dnvc2ssqirl32a@4ax.com...
    And bring another beer back with her !
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    It would seem that no one noticed the "AT" in power supply up there and
    making the rash assumption you actually meant AT, and not ATX, then the
    easiest 'no wires' solution would be an X10 appliance module, and a
    controller of course. You plug the AT PC into it, leave the PC switch on,
    and turn it on/off with the X10 controller.
    With wires just use an extension cord and a switched outlet strip in the
    kitchen.
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Does your BIOS offer a power on option for the keyboard? Alternatively,
    why not just leave it running?
    Cheers,
    Ari
    spammage trappage: replace fishies_ with yahoo
    I'm going to die rather sooner than I'd like. I tried to protect my
    neighbours from crime, and became the victim of it. Complications in
    hospital following this resulted in a serious illness. I now need a bone
    marrow transplant. Many people around the world are waiting for a marrow
    transplant, too. Please volunteer to be a marrow donor:
    http://www.abmdr.org.au/
    http://www.marrow.org/
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    I noticed it, but I made the rash assumption that he meant ATX.
  7. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >> and making the rash assumption you actually meant AT, and not ATX,
    I know what you mean. I rashed both ways for a moment before rashly
    settling on AT ;)
  8. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On 1 Aug 2005 12:38:22 -0700, "Pat" <guinnes0@yahoo.com> had a flock
    of green cheek conures squawk out:
    From your description is an antique pc, use a X10 power module to turn
    it on and off.
    If it's a modern one, check the bios for power functions with the
    keyboard/mouse.
    Stephen
  9. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On Tue, 02 Aug 2005 00:28:53 GMT As Androids Dreamed Of Electric Sheep
    I particularly like the,"Another" :D
  10. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    http://aaaremotes.com/houngadoreco.html
    Just hook the wires to the power switch terminals.
Homebuilt Power Systems
