G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have a 2.26 ghz CPU/Northwood/ 512 L2/533 FSB that I would like to use on
a new motherboard. One I'm looking at is the Asus P4P800-E Deluxe
(http://usa.asus.com/prog/spec.asp?m=P4P800-E%20Deluxe&langs=09) When I
first looked at the requirements of the new board, it says that the CPU is
"Socket 478 for Intel Pentium 4/Celeron up to 3.2 GHz+, seeming to include
"my" processor.
The memory needed is described as "Dual Channel Memory Architecture",
DDR400/333/266 non-ECC DDR SDRAM memory.
I'm a little confused. When I first bought the 2.26 Chip, only Rambus
(RDRAM) was available on an Intel chipset. I don't know enough about DDR
SDRAM memory. Will my chip work with this motherboard? And, if so, what
memory would be best?
I don't want to invest into a motherboard that will not be compatible with
my chip.
Can someone help?
Tom
"my" processor.
my chip.
Can someone help?
Tom
