G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi. Against my better judgment, my kids installed something on their PC -- a
Windows Longhorn service pack, or some such, which attempts to change parts
of the Windows XP interface to look like Longhorn (when it was still
Longhorn). It sort of worked (for a while) and then something went terribly
wrong. Now when you boot the machine, it shows the Windows XP loading
screen, then it prompts you to check the disk for errors (since it didn't
last shutdown properly), and then the following errors occur (all in message
boxes, not verbatim):
1. services.exe - Unable to locate component: App has failed to start
because SHELL32.dll was not found... [OK]
2. lsass.exe - Unable to locate component: App has failed to start because
3. User Interface Failure: The login user interface DLL msgina.dll failed to
load [Restart]
I've tried logging in via Safe Mode and rebooting to a command prompt, but
the same thing happens. I've tried booting from the Windows start-up disk,
but it doesn't have any effect. The drive may be bad, as we don't use it
much (it is recognized in BIOS/CMOS though). I did confirm the boot sequence
as A, C, SCSI. (In fact I reloaded the fail-safe defaults in BIOS just in
case). Before I go through the agony of switching floppies between PC's, is
there anything else I can try to get past this? Ideally, I could reinstall
Windows over the existing image, without losing any data. At the very least,
I would just like to access the file system.
Thanks in advance.
-jk
load [Restart]
Thanks in advance.
-jk
