G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Ok, I'm sure this isn't the first time this has been asked.
Just took delivery of my A8N-SLi Deluxe, Athlon64 3500+ (Venice, 1GB DDR400
Using all this to build myself a new system, and I already had a case
here ready to use with 400W Power supply. Problem is, the power supply
is a 20pin connector with the seperate 4pin ATX12v connector and the new
motherboard is the 24pin type (also with seperate 4pin ATX12v).
What do I do? - Can I use the 20pin in the 24pin connector and install
the 4pin also?
..... or am I looking at a new PS? - if so please recommend based on
above hardware
TIA
Jonni
the 4pin also?
above hardware
TIA
Jonni
