Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
I had removed everything starting via msconfig. I just went back
and nothing had been re-ticked. About 6 years ago, there was
a nuisance virus that caused the cd tray to open and close and I
thought this was a virus. But none of the scans can detect anything.
There are lots of games on this machine so I will start removing them
but at this point, I don't think that is the problem.
Thanks Peter for your help!
"Peter" <ivingtonAll_stRESS@fast24.co.uk> wrote in message
news:MPG.1d76b513c7c666ec9897dd@news3.fast24.net...
> In article <Fs0Pe.2048$db6.1189@bignews3.bellsouth.net>,
> lyn777@bellsouth.net says...
> > It seems that an autoplay command is coming from somewhere. I
> > can't find it with task manager.
> I take it this has only just started. Did you change/add anything
> recently program-wise?
> Try disabling all startup programs in msconfig. Does that stop it from
> happening? If not, then go see what's been re-enabled in the startup
> group. Is there anything suspicious now been re-ticked?
> > "Lyn" <lyn777@bellsouth.net> wrote in message
> > news:xo0Pe.2043$db6.794@bignews3.bellsouth.net...
> > > On hp7935 the cd door keeps opening and closing.
> > > I did a repair of operating system, have ran many
> > > anti-virus programs (zero viruses) and spyware programs
> > > (zero spyware) and cleaned the registry. I can't find
> > > what is causing it.
> > > What else can I check???
> > > Thanks!!!
> Pete Ives
> Remove All_stRESS before sending me an email
