wrong speed for cpu
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have a prescott 2.8ghz 512m fsb 800. My optimax mb says it is a 1.4
14x100.
Why does it get it wrong I have had this cpu in another machine and it
definitely a 2.8
Thanks
Jon
5 answers Last reply
More about wrong speed
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    A 2.8 GHz CPU for an 800 MHz FSB runs at 14X200. (The 200 MHz bus is quad
    pumped, hence 800 MHZ.)
    Your mainboard appears to be defaulting to 100 MHz rather than 200. If it
    supports 800 MHz CPUs (and has been updated for the Prescott), you may need
    to set the bus frequency manually in the BIOS settings.
    Address scrambled. Replace nkbob with bobkn.
    "Jon Smith" <usenet123@ntlworld.com> wrote in message
    news:T8rPe.2312$p4.1434@newsfe5-win.ntli.net...
    > 14x100.
    > definitely a 2.8
    > Thanks
    > Jon
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Hi,
    Most often you need to flash/update the BIOS so that it will recognise the
    chip/processor. But before you do that, make sure that specific model of
    optimax MB supports that specific chip. Check their website.
    Good Luck
    Andor
    > 14x100.
    > definitely a 2.8
    > Thanks
    > Jon
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    using correct speed ram helps also if you're using different ram aswell
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    was meant to be replying to the first post (the problem)
    Bob M wrote:
    > Who or what are you responding to? All we see is your reply. It
    > really helps to include the message you are replying to.
    > Bob
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Bob
Homebuilt Hardware CPUs Systems
