G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Built a new PC which for the most part is working just fine. I have an
older computer, and cable internet service. The older computer works fine
with regard to internet connection both when connected directly to my cable
modem and when going through my router. My new computer can't connect to
the internet at all when connected directly to the cable modem. When
connected through the router, it works fine. I can access the internet, use
email and other applications that require the internet connection. However,
there are 2 sites I can't find for some reason, even though I can access
them fine from the other computer.
www.pacificpoker.com and www.neteller.com
All other sites I know of are fine.
Any idea where I might start looking for clues here? thx
