G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
It has been a really long time since I last built a computer. A lot has
changed. My current computer keeps dying and trashing my boot partition
which has really hampered my research on what to buy. Guess where I
had my notes?
First off, I need a stable and reliable system. I am physically and
vocally disabled so my computer is my link to the world.
The computer will be mostly used to play Massively Multi-player Online
Roleplaying Games like EverQuest and Guild Wars. Ripping and burning
CD/DVDs is a lesser passion.
My budget isn't set yet but my harddrives, CD and DVD drives are new
enough to keep using. That gives me some freedom to spend more on
other parts.
So far my research points toward getting an Athlon 64. What are the
differences between the Clawhammer, Venice, and San Diego cores?
My current system is an Intel P4 2.4GHz. I'll probably be getting
an Athlon 3500+ or faster so it lasts me a while. Where is the best
bang for the buck sweet spot these days?
Since the Athlon 64 is a 939 processor, my next question is which
motherboard to buy and which to avoid? It needs to support X2 for
potential future upgrades. I'm not interested in SLI. PCI-E will
used for graphics as my old card is garbage. Is nForce 4 the best
choice? Is there more than one version on the nForce 4 chipset?
RAM these days has me confused. The new system will have one or
two gigabytes but the motherboard will likely dictate choices on
that.
My graphics card will be Nvidia. Likely a 6600GT but possibly a
6800 or 7800 of some type.
Any ideas on a decent tower case with a power button near the
bottom? My handicaps restrict my reach so that is important.
My current case is an AOpen desktop version but with two hard-
drives and a CD and DVD drive cooling might be an issue with
the newer processors and graphics cards. I'm not a fan of
noisy computers.
Any advice appreciated.
had my notes?
other parts.
that.
noisy computers.
