I need to buy a new power supply for my husband's computer, and I'm not sure what to get. We'd need a 350w - 400w, but do I just buy any Enermax, Antec, etc? I mean, do I need to know anything except "I want a 350w Antec." and go buy it at newegg, or is there some other spec I need to know?
I picked out all the components for the computer over a year ago, and the PS came with the case, so I don't know anything about replacing a PS I don't wanna miss anything when I go to buy one.
Crap. I just went out to Circuit City (hubs can't turn on his computer=grumpy) and picked up an Antec 400w Smartpower 2. This has got max 14A on the +12v1, max 15A on the +12V2.
Brand APower. Never heard of them, is a 500w ps, I asked for them to put in a higher one when I dropped off the components because a 300w was in the case.
Hm, looking at the differences in the Amps, obviously the 500w has a bit more. Do you guys think the 430 will be enough, or should I go get another 500w? Along with the hardware in the first post, he just has a normal DVD-RW drive, DVD-ROM drive and floppy drive and a western Digital 120GB. He plays alot of games, right now he's playing Call of Duty 2. There's a small amount of lights in the case. The computer has been *very* stable with the 500w.
Also, on a scale of 1-10, how difficult is replacing a power supply? Should I attempt this myself or take it to the Mom&Pop?
I've replaced hard drives, DVD-RW drives, memory sticks, etc, but never a power supply. What is the potential of frying everything? lol.
The 430 is probably able to provide as much or more stable power than the old 500w did since it came with a case - usually case-supplied PSUs are cruddy. There's nothing significant on that system and it doens't look like you're an overclocker, so I'd think the 430 would be fine.
Since you've screwed/unscrewed things and hooked/unhooked power leads, that's all that you'll do to replace the PSU (just unplugging everything in the case at once...), you should be fine.
