Yes No
Ads
No Sound Help!
Forum Windows XP : General Discussion No Sound Help!
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have the creaivelabs live x-gamer sound card. I have windows Xp with AMD
2500+ processor. Well i did the windows updates, well that just messed my
sound up. Every time i go to winamp and play music I get Crossfadin
Directsound output v1.37 error. bad direct sound driver. I tried
reinstalling, uninstalling and install drivers from the website. And it will
work UNTIL i restart the pc, then same error. I have the ECS L7A7S somwthing
like that motherboard, dont feel like looking it up. I tried reinstalling
directx, still nothing. Please help!
Reply to Anonymous
Ok, we'll go step by step:
If you have the drivers of your integraded sound card on the system,
uninstall them. Then uninstall Creative drivers.
Then restart and go to BIOS and disable int. sound card (press delete of F2
and go to (probably) Integraded Perhipeals).
Then it would be good to download the latest drivers for Live X Gamer from
Creative's website (www.soundblaster.com) and install them.... If you don't
want the latest drivers then install the ones from the bundled CD. If the
problem is still there then go to Sound And Audio Devices in Control Panel
and click the Audio tab. Then select SB Live in default device. And it
wouldn't be bad to go to Winamp > Options > Perferences > Output > Direct
Sound Output (double click) and select SB Live under device..... Please tell
me if it was successful!
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > General Discussion > No Sound Help!
There are 2117 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Microsoft Updates - In Triplicate !
By Hawkeye22, 2 days ago:
They won't show up in add/remove programs because they were superceded by a different...
Best offers
Top experts
