Sudden wireless network problem
Last response: in Wireless Networking
Archived from groups: alt.comp.networking.routers,microsoft.public.windows.networking.wireless,microsoft.public.windowsxp.general,uk.comp.home-networking,uk.telecom.broadband (More info?)
My home wireless network has worked flawlessly for months but one of my PCs
suddenly refused to work last night.
I have a BT Broadband connection (1Mb). This connection works OK since the
other PCs in my home connect OK (I am typing this from my wireless laptop).
My hardware is: BT Voyager wireless router/modem. Belkin wireless network
adapter. All running at 801g (54Mbit). I let my Belkin software manage the
connection (not Windows). I'm running Windows XP SP2.
Last night my Internet connection suddently went down. The PC was previously
working fine (and connecting to the Internet without a problem). The icon in
the system tray was reporting "limited connectivity" but I had something
else to do and ignored the problem.
But this morning the same problem arose. This time I appeared to have full
(90%) connectivity according to the icon in the system tray. So I expected
to connect to the Net without problems - but I couldn't (it timed-out).
Worse, I can't connect to my router's home page. But my PC reports that my
wireless adaptor is working OK and that I have connectivity (ranging from
90-95%). But nothing works.
Sometimes the system tray reports "limited connectivity" but if I disable
and enable the connection it goes back to (almost) full connectivity. But I
still can't "see" my wireless router (i.e. it's admin web page).
I'm at a loss. Help!
Cheers.
Bobby
Did you reboot the router?
"Bobby" <bobby@europe.com> wrote in message
news:3m5t5fF15ei48U1@individual.net...
> PCs suddenly refused to work last night.
> laptop).
> previously working fine (and connecting to the Internet without a
> problem). The icon in the system tray was reporting "limited connectivity"
> but I had something else to do and ignored the problem.
> I still can't "see" my wireless router (i.e. it's admin web page).
> Cheers.
> Bobby
> laptop).
> Cheers.
> Bobby
It may be something simple. Have any neighbours recently added a wireless
network? Have you installed anything that may be interfering? i.e. cordless
phone, cheap fan that generates a lot of r/f noise, fluorescent desk lamp.
etc.
Kerry
> Cheers.
> Bobby
Firstly try to check your TCP/IP settings. Do you use DHCP ?
try:
start/run/cmd
ipconfig
If everything looking alright try to check your WEP and SNR.
If still isn't working I could propose you to check your firewalls,
antyvir softwere at your PC.
Best Regards
Marcin Gaszewski
Related ressources
In article <3m5t5fF15ei48U1@individual.net>, Bobby says...
If you're using MAC address filtering, check that.
Conor
If Pac-Man affected us as kids, we'd all be running around in darkened
rooms, munching magic pills and listening to repetitive electronic
music.
On Sat, 13 Aug 2005 07:32:30 -0400, "Rick \"Nutcase\" Rogers"
<rick@mvps.org> wrote:
>As it is an all-in-one unit, I would disconnect the machines from it during
>this operation.
sure. For info, in the UK separate ethernet ADSL modems are not very
common, and are usually a nuisance as the default DSL service is PPPoA
and not PPPoE.
Cheers,
Phil
Remember - Global Warming is only a weather forecast :-)
Try this:
http://www.spychecker.com/program/winsockxpfix.html
"Kerry Brown" <kerry@kdbNOSPAMsys-tems.c*a*m> wrote in message
news:uTI78kBoFHA.3448@TK2MSFTNGP12.phx.gbl...
>> the other PCs in my home connect OK (I am typing this from my wireless
>> laptop).
>> the connection (not Windows). I'm running Windows XP SP2.
>> connectivity" but I had something else to do and ignored the problem.
>> full (90%) connectivity according to the icon in the system tray. So I
>> expected to connect to the Net without problems - but I couldn't (it
>> timed-out). Worse, I can't connect to my router's home page. But my PC
>> reports that my wireless adaptor is working OK and that I have
>> connectivity (ranging from 90-95%). But nothing works.
>> Cheers.
>> Bobby
> cordless phone, cheap fan that generates a lot of r/f noise, fluorescent
> desk lamp. etc.
> Kerry
In an earlier contribution to this discussion,
Bobby <bobby@europe.com> wrote:
> Thanks for the suggestions.
> The problem PC is a desktop system (not a laptop).
> The network also includes two laptops (including the one I'm typing
> this on) and another desktop PC. All connect wirelessly. All work
> perfectly.
> My problem PC was working perfectly. I did not make any network
> changes. I am reluctant to stop messing about with TCP/IP settings.
> My modem and router is a combined unit. I switched it off last night
> but the problem persisted this morning when I tried again. I presume
> switching it off is the same as a reboot. The lights on the
> modem/router report no problems whatsoever and every other PC/laptop
> works OK.
> I can't connect to my modem/router web management page so something
> fundamental must be going wrong between my PC and the router.
> I am going to try to re-install my wireless network adaptor software.
> Then I will replace my wireless adaptor to see if that helps.
> Bobby
Have you re-booted the problem PC? Does that help?
If the PC *appears* to be connected to the PC but can't talk to it, some of
the PCs wireless settings may have got corrupted somehow.
What level of wireless security are you using - encryption, MAC address
filtering, hiding SSID, etc.? If using encryption, make sure that the type
and parameters are set up on the PC exactly as on the router. If using MAC
address filtering, make sure that the PC's wireless card's MAC address is in
the router's Permitted table.
Can you ping the router from the PC?
You can *check* the PC's TCP/IP settings without having to mess with/change
them. When you type "ipconfig /all" at the Command prompt, does it display
an IP address in the same range as that of the router, and with the same
subnet mask?
[If you don't know how to interpret what it is telling you, copy the output
from ipconfig /all and paste it into this thread - preferably with the
equivalent output from a PC which *does* work].
Cheers,
Tim
______
Please reply to newsgroup. Reply address is invalid.
"Tiscali Tim" <tele@privacy.net> wrote in message
timothy dear why do you call yourself tiscali timmy when you dont even use
piscalli :-)
> even use piscalli :-)
Perhaps for the same reason as you call yourself <@> ?
Cheers,
Tim
______
"" wrote:
> On Sat, 13 Aug 2005 07:32:30 -0400, "Rick "Nutcase" Rogers"
> from it during
> >this operation.
> not very
> is PPPoA
> and not PPPoE.
> Cheers,
> Phil
"ethernet ADSL modems"
You mean a router? Like the one I have? (I live in England)
"and are usually a nuisance as the default DSL service is PPPoA and
not PPPoE."
You sure about that? My BT connection work with both PPPoE and PPPoA.
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/General-Discussion-Sudden-...
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1355384
On 13 Aug 2005 19:35:40 -0400, Sparda
no, I mean an ADSL modem using ethernet to connect to a single device.
>not PPPoE."
yes I am sure, the default is PPPoA, it is the one BT recommend, they
also added support for PPPoE which AOL use for one. I don't believe
all ISPs support PPPoE (it adds overhead and an extra client).
Phil
Warning: Do not look directly into laser with remaining eye.
Thanks for all the suggestions.
The prize goes to the people who suggested that my network settings had got
corrupted.
But no-one got the solution -- restoring the PC using system restore.
Although I guess the WinSock fix would probably have worked too.
I think that the problem was caused by a Windows update. I think that I
switched off my PC during an update - Windows reported this and said that I
could continue the shutdown but I think that my problems arose after this.
Anyway, system restore solved my problem. In fact, system restore solves
every (software) problem in my experience.
Thanks again to everyone who contributed to this thread.
Bobby
"Ed." <esmithoh(at)zoominternet.net> wrote in message
news:o YyorfEoFHA.2580@TK2MSFTNGP09.phx.gbl...
> Try this:
>>> laptop).
>>> network adapter. All running at 801g (54Mbit). I let my Belkin software
>>> manage the connection (not Windows). I'm running Windows XP SP2.
>>> disable and enable the connection it goes back to (almost) full
>>> connectivity. But I still can't "see" my wireless router (i.e. it's
>>> admin web page).
>>> Cheers.
>>> Bobby
>> desk lamp. etc.
>> Kerry
On Sun, 14 Aug 2005 10:40:43 +0100, "Bobby" <bobby@aventuremail.com>
can also leave you with a broken windows installation requiring a
re-install :-(
Phil
In article <3m8hssF15s66gU1@individual.net>, "Bobby"
bobby@aventuremail.com says...
<snip>
It solves nothing in my experience, but that could be because I
always disable it because of the problems that it has caused me in
the past :-)
On Sun, 14 Aug 2005 12:20:53 +0100,it is alleged that Rob Morley
<nospam@ntlworld.com> spake thusly in uk.telecom.broadband:
><snip>
>the past :-)
I believe it induces a false sense of security in people, I have
disabled it also, I prefer to backup using norton ghost :-)
Life is a whim of several billion cells to be you for a while.
> always disable it
Yes, that might be the reason.
Disabling system restore IMO is not a good idea. It solves 99% of software
problems.
In article <3m9agnF15blonU1@individual.net>, "Bobby"
> > always disable it
> problems.
Why did you snip the bit that said "I always disable it because of
the problems that it has caused me in the past"?
Archived from groups: microsoft.public.windows.networking.wireless,microsoft.public.windowsxp.general,uk.comp.home-networking,uk.telecom.broadband (More info?)
"Bobby" <bobby@aventuremail.com> wrote in message
news:3m9agnF15blonU1@individual.net...
>> always disable it
> problems.
And, even if you cant get windows up and running, you can use the restore
settings to recover your previous backed up registry.
If you have system restore switched off, unless you manually backup your
registry, and your registry files get corrupted, then your installation is
unrecoverable.
Gaz
Quaoar <quaoar@tenthplanet.net> wrote:
> Assuming that the problem PC runs XP, download a copy (Google) of
> winsockxpfix.exe and lspfix.exe. Run both (although winsockxpfix
> seems to do the work of both) to repair layered services that can
> become corrupted for no apparent reason that I have been able to
> ascertain. The corruption leads to exactly the type of problem you
> describe.
Is it likely to fix a problem which I have with my laptop?
The laptop normally connects to the internet via my router, using its
ethernet connection - no problem. However, if I am away from home, I use it
to dial into the internet, using it's built-in modem. The problem is this:
If I dial in and then disconnect, I cannot connect again without re-booting.
Actually, that's not strictly true. I can *connect* to an ISP but I can't
actually *do* anything. If I look at the config in ipconfig /all, it's
apparent that it's left behind a stray PPP record which I can't get rid of
without re-booting - and although dialling in again creates a new one, it
doesn't pick up the gateway and DNS addresses properly. I've tried all the
ipconfig options (dnsflush, etc.) but nothing works.
Anyone got any ideas?
Cheers,
Tim
______
>> describe.
> use it to dial into the internet, using it's built-in modem. The
> problem is this:
> re-booting. Actually, that's not strictly true. I can *connect* to an
> ISP but I can't actually *do* anything. If I look at the config in
> ipconfig /all, it's apparent that it's left behind a stray PPP record
> which I can't get rid of without re-booting - and although dialling
> in again creates a new one, it doesn't pick up the gateway and DNS
> addresses properly. I've tried all the ipconfig options (dnsflush,
Give winsockxpfix.exe a try for this. It is essentially harmless, IMO,
based on the lack of negative comments on its use.
Q
Ask the community
