Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Water cooling on non-OC computer?
Forum Overclocking : Cooler and Heatsinks - Water cooling on non-OC computer?
Is there alot of gain to water cooling a system if you aren't going to OC it?
Sponsored Links
No, no no... unless you just want the coolness factor and even then it is NO!
Reply to RichPLS
Sure, longer life.... and the potential for overclocking!!!
Reply to 94blue302gt
Quote :
hey retard....he said he wasn't going to OC....and longer life is a joke. Yeah some people have machines that are 15yrs old....but they dont use them for anythign but folding.
Reply to pickxx
Basically if your not oc's, water only quiets PC, but with 20dB heatsinks, those are silent also, like Thermaltake Orb at 17dB is pretty quiet and cools good enough for oc'ng some too.
Reply to RichPLS
Also, if Water springs a leak while PC is plugged into socket, even off, can short out entire shabang! It is risky to be so cool with water and no clue.
Reply to RichPLS
I hate water cooling, in my opinion try to avoid it if there are alternatives out there. how often people come to your house and go "Wohh check out this phat water cooling" I dont think its happening. Also, last time I checked, installation is not that simple.
Reply to toastman
by the way, since im not familiar with dB, is 20dB is considered silent? Would you hear it from 3 meters away?
Reply to toastman
Reply to toastman
I'll take that as a "I dont know" :P
Reply to toastman
I think that PC fans are rated at 1 foot what I read today, audio equipment is rated at 1 meter.
Whichever standard is used, at 3 meters would be much further, so chances are you would not hear but a low pitch hum, and it might be indistinguishable with the background noise if you have nothing else running to contribute to the noise from your PC. The case fans make other noise, the PSU makes noise, the HD's make noise, etc...
But two 17dB makes somewhere around 27 dB, not 34, and three 17dB fans would make around 37dB, not 51dB
Reply to RichPLS
Depending on what is cooling and how you set up the radiator you could make a completely passivily cooled PC - No noise.
Reply to Ned_Flanders
No, two 17db fans would make 20db. Three would make 21.5db. Four would make 23db.
Reply to Crashman
There are 1224 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
