Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > Problem syncing work appointments on my home pc when there..
Forum Smartphones & PDAs : Windows Mobile - Problem syncing work appointments on my home pc when there..
Archived from groups: microsoft.public.pocketpc (More info?)
I actually sent this same request to Chris D via e-mail, so Chris sorry
if you see this twice.
I am having trouble syncing appointments at work and then at home when
they have attendees listed. If there are attendees included in the
apointment then I get "unresolved .." error messages when syncing.
From Chris' site:
Another source is when users are inviting users to appointments which
do not exist on the PC (normally their home PC) they are synchronizing.
In this case you need to either add the users to the Pocket PC and sync
it with their PC or delete the invited attendees for the appointment.
You cannot just add the user to your PC because the Pocket PC is
looking for that specific contact that existed previously.
Is this problem found with all versions of ActiveSync? I am still using
3.5 at home and was wondering if an upgrade would fix the problem.
The invitees are users from my company's address book, not my personal
contacts which explains why they are not in the set of contacts on my PPC
or home PC. The response above says to either delete them from the
appointment or add them to the PPC and sync with the home PC. Removing
them is not a great option because I'd like to have a record of who was
there. Is there an easy way in Outlook to copy corporate contacts to my
personal folder?
There has to be a better way. I have to feel this is a common problem.
Thanks,
John
RPA - Raggio Pocket PC Applications
www.theraggios.com/rpa
Sponsored Links
There are 1316 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
