Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi, I have 3 problems:
When I start Microsoft XP (SP1) I get next message:
1/ LSA Shell (Export Version) encountered a problem and needed to close.
Tell Microsoft about this problem...
2/ Sometimes when I am connected, little window appears with 1 min to
turning off the computer.
3/ Self disconnect from the internet after 1 min.
I think that maybe it's Sasser worm, but I can't find it.
I install Windows and Norton updates but nothing help
What can I do to solve this?
Thanks
Sponsored Links
hi, i'm Roman i have encounter the same problem as yours, the is a worm virus
that infect the file LASS, something like that, then only when u connect to
the internet after a while it shows you a screen an error and turn off ur PC,
u need to install an update to secure ur computer, and Eliminate that
problem, download the update from here:
http://download.microsoft.com/down [...] 86-ENU.EXE
try to download it as fast as u can, after u will download it then install
it, once u have installed it reboot the PC, once u reboot the problem will
gone, disappear.
It highly reccmomend that u install Service Pack 2 on WIndows xp, to
eliminate all winxp problems, the security problem and the orginial, if u
won't download service pack 2 soon u won't be able to use ur windows, after u
install the update(i gave u the link up there) download and install service
pack 2 from:
http://download.microsoft.com/down [...] /xpSP2.exe
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > 3 problems in XP
There are 1253 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
