Power supply for new system
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power supply for new system
Hey,
I am putting together a new system and was wondering if the power supply I am planning on using is ok. I did not want to spend too much on a psu, but I also wanted something that was not a piece of crap and that would ruin my system and eat up a ton of electricity. The system is as follows:
ABIT KN8 Ultra
AMD Athlon 64 3200+ Venice
OCZ Gold Series 1GB DDR 400
6800 GS
Western Digital Caviar SE WD1600JS 160GB
NEC ND-3540A
Creative Sound Blaster Live! 24bit
FSP AX450-PN ATX12V 450W: http://www.newegg.com/Product/Prod [...] 6817104954
Thanx
Sponsored Links
Any other drives? CDRW or DVDRW? That FSP should be good with that system. Try it and if it doesn't work then you can replace. I'm not sure how much OC you can pull out of it, but it will run the system at stock speeds.
Reply to Rugger
That's more power supply than you need, you'll be fine.
Reply to Crashman
Thanx for replies. I am actually wondering if this drive will be power efficient and quality. I will eventually be adding a 7800 of some type and a dual core and more RAM, but no otehr drives. Also, I will not be o/cing
thanx
Reply to alladinsane
The drive? I've never looked into the power efficiency of drives. The power supply was notable for being efficient not very long ago, before the competitors started getting efficient.
Reply to Crashman
oops, i meant to write "psu", not "drive"
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power supply for new system
There are 1226 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
