new system won't post
drbobbo
recently built a new system, specs are:
amd athlon 64 3000+ venice
asus a8n-vm
antec truepower 430 watt
512 (2) corsair VS ddr400
on powerup, system won't post, all the fans are working and the mobo has power. no abnormal beeps either. I reset the cmos and tried reseating the cpu, but it didn't help at all. any suggestions would be incredibly helpful, as I don't want to have to replace the cpu if the real problem is the motherboard, and vice versa.
dunklegend
2,079
Try it with only one stick of ram and remove any cards that are not necessary
Check all the cards and connectors.
Make sure that you have the mobo spacers in the right places...
And cross your fingers.
I'm having a no video problem myself, so I know how frustrating that can be.
Good Luck.
