I had a small incident where my place flooded in and water reached the lower section of 2 of my motherboards when fixed on tower casings, the PCs were both turned off when this happened and I quickly moved them to higher ground. I have since then evaporated the water using a hair dryer and a high speed blower and set the motherboards out to dry for 2 days. I pluged them in yesterday and both boards don't seem to start up.
Does this mean that they are both damaged? Would I have done the damage when I plugged them in and powered up yesterday? Should I have waited for a longer period of time before powering them up? Is there any chance of getting them to work if I let them dry out some more?
I was using these 2 boards on 2 Video editing systems.
1) Gigabyte 8INXP - (i7205)
I was using the onboard Promise IDE RAID in standard ATA mode to have four 120GB Maxtor HHDs run a software RAID through disk stripe in Windows 2000 Disk Administrator. Is there any way I can retrieve the data?
2) ASUS P5WD2 Premium - (i955X)
Was using the onboard Intel SATA RAID in ATA mode to run a 2 drive software RAID in Windows XP. Any Idea how this data can be retrieved?
Any suggestions on how to get these boards working if possible would be appreciated. If the boards are dead how would I go about getting the data on the software RAID? I was thinking if in a worst case scenario to replace the boards with identical boards, this is possible for the ASUS P5WD2 Premium as it is available for sale, but the Gigabyte 8INXP is not longer available and I can't seem to find one for sale anywhere yet. Please help.
Thanks
Thanks
