Archived from groups: microsoft.public.windows.networking.wireless (More info?)
We are trying to figure out how to get a portion of our LAN wireless. We
have 9 users that would be affected by this and the area that would have to
be supported would be about 300 ft.
Our network consists of a T1 coming into the building, then going out to
other buildings using fiber optics. There are 6 small (4-5 rooms) buildings
that are currently using coax and BNC connectors, and we are having problems
with the electrical storms taking out the BNC - RJ-45 devices. The 6
buildings house about 9 users total.
We have done some research and found 3 different types of wireless access
points.
1. 802.11a
2. 802.11b
3. 802.11g
I am familiar with the B and G, but not with the A. And then we found one
that combines A and G. Can anyone give me some advice to what we will need?
Hi
The current main stream Wireless is 802.11g which is down compatible with 802.11b.
If you do not have users that specifically use 802.11a you do not need it.
Wireless is heavily depending on the envioroment it is not so much an issue of what to
buy but rather how it should be set to provide adequate coverage. It seems to me that
you need a professional consultant to survey the site and give you advice.
Jack (MVP-Networking).
"Drew" <drew.laing@NOswvtc.dmhmrsas.virginia.SPMgov> wrote in message
news:#CYy5tyoFHA.3936@TK2MSFTNGP10.phx.gbl...
> points.
> 1. 802.11a
> 2. 802.11b
> 3. 802.11g
> Thanks,
> Drew
If I'm not mistaken (if I am, hopefully someone will correct me ), "a" is
for direct WAN (cellular) connectivity. Like... Sprint, Verizon, Cingular,
etc. Normally not used by the average Joe. Occasionally, if both are used,
it can be advantageous to have both A and G supported in one card. But is a
somewhat rare requirement. B and G are both typical wireless standards. G,
the fastest and most recent, is downward compatible with B. In today's
world, barring any unusual requirements, you would want G.
-Frank
news:%23CYy5tyoFHA.3936@TK2MSFTNGP10.phx.gbl...
> to be supported would be about 300 ft.
> buildings that are currently using coax and BNC connectors, and we are
> having problems with the electrical storms taking out the BNC - RJ-45
> devices. The 6 buildings house about 9 users total.
> points.
> 1. 802.11a
> 2. 802.11b
> 3. 802.11g
> need?
> Thanks,
> Drew
Nope "A" has nothing to do with cellular. Generally you would want to
support "B" or "G" with "G" being the newer standard. "B" will be required
if you wish to support users with Windows Mobile Pocket PCs. You may want to
think about "A" if you want the extra security it may provide, by being less
popular.
David Hettel
Microsoft MVP
Mobile Devices
"Frankster" <Frank@SPAM2TRASH.com> wrote in message
news:E5mdncgJnYPu757eRVn-1g@giganews.com...
> is for direct WAN (cellular) connectivity. Like... Sprint, Verizon,
> Cingular, etc. Normally not used by the average Joe. Occasionally, if
> both are used, it can be advantageous to have both A and G supported in
> one card. But is a somewhat rare requirement. B and G are both typical
> wireless standards. G, the fastest and most recent, is downward compatible
> with B. In today's world, barring any unusual requirements, you would
> want G.
> -Frank
>> points.
>> 1. 802.11a
>> 2. 802.11b
>> 3. 802.11g
>> one that combines A and G. Can anyone give me some advice to what we
>> will need?
>> Thanks,
>> Drew
Yep. Thanks for that info. I've now taken time to look it up and it
appears that the most significant difference between "a" and "g" is that "g"
operates on 2.5Ghz to maintain compatibility with "b" whereas "a" operates
on 5Ghz. Since "g" has won the popularity race and it is compatible with
"b", "g" is the way to go.
UNLESS.... and I kinda like this part, you are having a lot of interference
from your 2.4Ghz radio telephones in proximity to your wireless nodes.
Then, I guess the "a" operating at 5Ghz would be preferable.
For anyone else that is as clueless about "a" as I was, here's a good
link...
Thanks for the info and links! I will keep diggin around and see what I can
find...
Drew
news:-pGdnX40x_4xmJneRVn-jA@giganews.com...
> "g" operates on 2.5Ghz to maintain compatibility with "b" whereas "a"
> operates on 5Ghz. Since "g" has won the popularity race and it is
> compatible with "b", "g" is the way to go.
> interference from your 2.4Ghz radio telephones in proximity to your
> wireless nodes. Then, I guess the "a" operating at 5Ghz would be
> preferable.
> link...
> http://www.tutorial-reports.com/wi [...] n_wifi.php >
> Sorry for any miss-info.
> -Frank
Another reason to go with "A" is that it will not interfere with a video
sender, so if you are wirelessly transmitting video from one room to another
you'll want to disable the "B" and "G" or go with an "A" mode Accesspoint.
David {MVP}
Microsoft Mobile Devices
Mobile AntiVirus Researchers Association
This posting is provided "AS IS" with no warranties, and confers no
rights...
Spelling and grammar errors left in for those that need a little joy in
their life by correcting me.
news:%23DkLtyNpFHA.764@TK2MSFTNGP14.phx.gbl...
> can find...
> Drew
>> preferable.
>> link...
>> http://www.tutorial-reports.com/wi [...] n_wifi.php >>
>> -Frank
