Archived from groups: microsoft.public.windowsnt.misc (More info?)
I successfully applied service pack 6a to my NT 4.0 box (Dell XPS R450
(Pentium II)), and then applied the post-SP6a hotfix from Q299444. NT
now comes up with a "one or more services failed, check the event log"
on startup, with no keyboard or mouse.
After a bit of googling, it seems that this could be a known issue
which might be alleviated by editing one or more registry keys
(HKLM\System\CurrentControlSet\Services\(mouclass|kbdclass|msi8042|i8042prt)\Start)
and setting the value to "1" (if set to "0" or "4" which apparently
disable the keyboard/mouse).
My problem is that the computer in question is not on a LAN (only
dial-up Internet access), does not have a working floppy drive (broken
for a while, haven't needed it recently), and the partitions are
NTFS-formatted except for a single FAT partition shared in dual-boot
setup with a RedHat Linux 5.1 install (from which I'm posting this
message).
Basically, what are my options re editing the registry on this
computer? So far I can think of:
1. install a new floppy drive, boot off it (if possible) using the
rescue disk, and edit the registry ;
2. install a new floppy drive, boot off it (if possible) to install
a "temp" version of Windows NT, edit the original registry file, then
revert to the original Window NT installation ;
3. physically remove the hard-drive containing the Windows NT
install, place it in another Windows box (a Windows2000 box?), edit
the registry file, then return the drive to the original box ;
4. or ...?
If (3) is plausible, do the Windows' registry tools allow an arbitrary
registry file to be edited (i.e. I'd want to edit the registry on
H:\WINNT\SYSTEM32\???? instead of the "real" one for that box)? Are
there other tools that allow that? Actually, what's the "filename" of
the Windows registry in NT 4.0?
Thanks in advance for any help/information/pointers.
Jim
message).
4. or ...?
Jim
