Ok,
I have made various threads to get help with my new system that i am building.
The specs will be:
AMD 64 3200+ (Venice Core)
Epox 9NPA+ Ultra
1GB (2x512mb) Corsair Value S. PC3200 DDR
GeForce 6800GT (PCI-E)
250GB Maxtor ATA/133 Hard drive
I am looking for a decent powersupply that will power this, I am from the UK and the prices are alot higher here from what i can see. I dont want to spend more than £65, which is about $110 i think.
Unless anyone can suggest a better PSU from that site.
Btw, i noticed that it does not support 'Dual Fan', i currently have a Fan on the front of my case, and the side pannel of my case (X-blade Case). Does that mean i cannot power both of these at once?
Not a problem - glad I could help! Take your time when you do the build - read the manuals, especially mobo, and the FAQs from the CPU, Mobo, Graphics Card and Hard Drive forums before you start putting parts together. Good luck with the build!
