having a problem with my pc
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - having a problem with my pc
I turned on my computer for the first time and it starts to load up then it restarts itself and won't finish loading what would cause this?
Sponsored Links
over heated CPU.
Check your CPU paste and all that good stuff. Take off the HSF.
also maybe Power supply.
I'd check the CPU thing out first.
Reply to Rob423
- 0 +
sorry about the email didn't see the reply button well the temp said 44c/ 111f I did not think that was too bad but will check the cpu again.
Reply to ralh182
- 0 +
Is this a new build? First time to power it up or has it been running fine for a time? Have you done anything recently - any upgrades/updates to the rig? What are your system specs? Be specific - mfr/model. 44C at idle or under full load? That could be high or low - depends on the circumstances and the CPU.
Reply to Rugger
- 0 +
the computer is a new build that I just fired up. The specs are Biostar NF325-A7 with An AMD 3400+ Socket 754, I have a 256mb 9600 XT graphics card, 512 mb pc2700 ddr memory stick.
Reply to ralh182
- 0 +
That's high for a skt 754 at idle - especially since your FSB is probably running at 333 because of the RAM you have in the rig. You can verify the speeds of RAM/CPU with CPU-Z.
Reply to Rugger
- 0 +
well what is the best way to apply thermal paste cause I have applied it a few time and each time was a little different and the results are the same. links to pics would be helpful also. I thought it might be the power supply, but borrowed one from a from and that was not it. Thank you for helping me.
Reply to ralh182
- 0 +
First try opening the side of the case and see how that affects your temps.
Reply to Rugger
- 0 +
when I checked it the side was off and did not help any.
Reply to ralh182
- 0 +
When i apply thermal paste, I apply some to the middle of the die and then use a credit card to evenly spread it on top of the die. Read your mobo/cpu manual for specific instructions. If you've already reapplied, then did you remove the old paste with 99 percent rubbing alcohol before reapplying? Off the HSF and CPU...
Reply to Rugger
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > having a problem with my pc
There are 1262 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
