I built a new system about 4 months ago. Everything has worked awesome on it untill today. I was playing FSX when the computer froze. I tried closing it with the task manager, but the "ending program" window went to not responding. I left it a few minutes, nothing would respond so I shut the computer off and restarted it.
On restart windows would freeze on the starting windows screen (before the logo comes on). I tried restarting it a bunch of times, it would freeze at the same spot, or on the black screen right after the boot screens.
I decided to do a clean install win7 (formatted, deleted the partition, new partition, and formatted again). The install went extremely slowly, it took almost 3 hours. It spent well over an hour "expanding windows files." It finished that, installed the features and upgrades. It configured for awhile, restarted did the registry configuration, then went to the progress screen again. It restarted a while I wasn't looking and froze on the windows screen on start.
I rebooted, and it came up on the windows error recovery screen, so i tried starting in safe mode, and the computer froze again after
Loaded: \Windows\system32\DRIVERS\CLASSPNP.SYS
Another reboot to error recovery, tried to start normally and it froze on "Starting Windows"
So after about 5 hours messing around getting no where I thought it was time to do what I should have in the first place. Ask the pro's here.
System specs
Asus P6X58D-E
i7 950
6 gb Crucial Ballistic DDR-3 1600 ram
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
Sapphire Radeon 5870 2gb eyefinity 6
Samsung BD-Rom
Ok so while writing this after about 35mins it seemed to come to life (off the starting windows screen) and started for the first time, had me enter the product key etc.
Sorry for the rambling post, but I'm hoping somebody can help me find and fix my problem.
System specs
Asus P6X58D-E
i7 950
Samsung BD-Rom
