Sound software.... Do you need drivers?
You have a pentium 4 system running OS 7 ultimate? Windows 7 Ultima maybe?
Well if you need Win7 drivers for a Pentium 4 system it could be tough to find them. Win7 should come with the drivers but if they are not included with the install disc you may be out of luck. You'd need to give the motherboard make and model you are using.
Also, I have a Pentium 4 CPU glued to a long stick that I use as a backscratcher. It really works well and I don't need any drivers for it.
