Archived from groups: microsoft.public.windowsxp.basics (
More info?)
"BlueRiff" <anonymous@discussions.microsoft.com> wrote:
>I've got a simple problem, screensaver on winXP home
>doesn't come when set to more than 4 mins. I've got an
>integrated video (intel), standard mouse and KB. What can
>I do, thanks!!
Check your startup settings to find out if a software running in the
background is causing this. Applications that start with Windows can
be found here:
- the WIN.INI, section [windows], entries "run=" and "load="
- the Registry keys
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices
- the folders
C:\DOCUMENTS AND SETTINGS\ALL USERS\START MENU\PROGRAMS\STARTUP
C:\DOCUMENTS AND SETTINGS\{username}\START MENU\PROGRAMS\STARTUP
See also "How to Troubleshoot By Using the Msconfig Utility in Windows
XP" (http://support.microsoft.com/?kbid=310560) and "How to Perform a
Clean Boot in Windows XP" (http://support.microsoft.com/?kbid=310353).
(tm)
