Well, i am soon about to start building my new PC.
The Specs are.
AMD 64 3200+ (Venice Core)
Epox EP-9NPA+ Ultra
535W Enermax FMA SLi PSU
XBlade Case
1GB Corsair Value Ram (2x512mb)
250GB ATA/133 IDE H/D
Now, This is my first ever build, therefore i have never installed a motherboard but think i know what i am doing when it comes to the cabeling.
Anyhow, is their any tips when it comes to actually inserting the Mobo into the case? As i saw a post by someguy that destroyed his Mobo as soon as it touched the metal of the back of the case.
If that does happen as soon as it touches, then is their any advice on how to install it safely without destroying it?
Do i just place the mobo within the case (about 1/2 inch from the metal) and screw in the screws?
Any help or advice on Anything to do with building the PC is appreciated (even if it has nothing to do with mobo installation, help is greatly appreciated.)
Oh, yea, should i format my current HD on my current PC and install windows now, so that its ready to just insert the HD into the new PC so its windows ready? or should i just format it, then reinstall windows XP on the new PC?
Thanks again.
The Specs are.
Epox EP-9NPA+ Ultra
XBlade Case
Thanks again.
