Ok, there are a pluthera of water pumps for fountains/ponds that have pretty good pumping numbers for the system, but they all have a system that makes them have to sit on the bottom of the tank or whatever, not a direct feed. I'm not going to just put this pump in a pan of water and let it pump everything through and then just have it dump again! Is there a better solution? Or do i just have to buy an actual 12v pump? The reason i ask is cuz i can pick these things up for liike 12 bucks no problem, and they pump pretty good.
