word document problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi! Please help!! I am using works processor to make documents (because I
like the options and the use of the tables) and when I send them, some
recipients can not open the attachments. I do save the documents as word
97-2000 rtf. and it helps some of the time. Also, when I receive documents
that are word, word viewer opens them and I cannot edit it them. So, if i
have to edit, I must copy and paste to processor doc. and edit then change
back to rtf. Word 97-2000 and resend it . It is a pain, and sometimes in all
the shuffling, my document does not look the way I want it to???????????????
Any advice!!
More about : word document problem
Sorry to say, but sometimes it's better no to go against
the Grain!
If you want to be compatable with the rest of the world,
you have to use what they use. Let go of the Past!
You are going to have these issues as long as you are
using Works for "Professional" services, as most people
around the world use office
Best to stick to Office 2000 or better, and uninstall 97.
Use the "Save as" fuction when your saving Documents!
Dont forget to apply the latest service pack for
whichever product you are using!
I hate to come over as a big meanie, but try to send only
office doccuments in your emails, this will help other
people read your doc's, Most people don't use Works!
Good Luck
>-----Original Message-----
send them, some
documents as word
I receive documents
it them. So, if i
>Any advice!!
"sweetie" <sweetie@discussions.microsoft.com> wrote in message
news:A542160E-A459-4E44-A07A-96418AB4A4B4@microsoft.com...
Is that an editor-related thing or a security issue. E-mail clients can be
setup to block any attachment...
documents
all
to???????????????
> Any advice!!
Word 97-2000 has options too and lets you use tables as well, you know.
Besides, you'll avoid the
copy-from-the-viewer-and-paste-to-your-works-editor headache and also Word
is more reliable than works (as far as I know!)
Av.
Maybe the recipient has an older version of Word, than was used to create
the documents.
"phoenixuss" <phoenixuss@comcast.net> wrote in message
news:kL-dnW72Hc6CS4HcRVn-hw@comcast.com...
I
word
be
> documents
i
change
in
> all
> to???????????????
> > Any advice!!
> Av.
Ask the community
