SHLWAPI.dll problem upgrading to IE 6.0
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.misc (More info?)
I have to apply all current security patches to a NT 4.0 workstation. It was
version 4.0 Gold when I started this morning, but I have applied SP6a from a
CD and the post 6a security rollup. I tried to upgrade IE from version 2.0
to 6.0 SP1 but got the following message when I tried to run the executable:
"The procedure entry point StrNCatA could not be located in the dynamic link
library SHLWAPI.dll" The version of SHLWAPI.dll is 4.70.1215.
I working on applying a number of security patches but would like to get IE
up to date also. Any suggestions would be appreciated.
Dino
G
Guest
Guest
Try upgrading IE to version 4 first. This version is available from the
SP4-Option Pack CD and from these sites:
http://helpdesk.uvic.ca/software/downloads/windows/msiexpl.html
http://www.webzila.com/downloads/downloadscript/pafiledb.php?action=category&id=2
http://browsers.evolt.org/?ie/32bit
Hal
Hal Hostetler, CPBE -- hhh@kvoa.com
Senior Engineer/MIS -- MS MVP-S/U -- WA7BGX
http://www.kvoa.com -- "When News breaks, we fix it!"
KVOA Television, Tucson, AZ. NBC Channel 4
Still Cadillacin' - www.badnewsbluesband.com
"Dino J" <DinoJ@discussions.microsoft.com> wrote in message
news:FBA6EFC9-A5F3-4840-ABB1-1FF60E018B10@microsoft.com...
>was
> a
> 2.0
> executable:
> link
> IE
> Dino
G
Guest
Guest
I have IE ver 4.01 on a CD and received the same message when I attempted to
install it. but thanks for the suggestion.
> Hal
> >was
> > a
> > 2.0
> > executable:
> > link
> > IE
> > Dino
