Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have Comcast cable - 4000 kbps when hard-wired from a LinkSys Cable modem
(BEFCMU10) to a LinkSys Router (BEFW11S4) to my desktop computer. I also
have a LinkSys signal booster (WSB24) connected to the router, but probably
don't need it.
Problem: on my laptop, one time I got 350 kbps, but most times times I get
much slower. Today I clocked it several times at between 50 - 150 kbps.
Why can't I get close to the 4000 kbps that my hard-wired desktop gets?
My laptop (HP Tablet PC 1100) has an Intel Pro/Wireless 2200BG Network
Connection, and all settings are at default. My signal strength is
excellent (11.0 Mbps). On another laptop (Gateway), speeds are also slow:
typically 50 - 100 kbps.
> modem
> also have a LinkSys signal booster (WSB24) connected to the router,
> but probably don't need it.
> I get
> kbps.
> gets?
> slow: typically 50 - 100 kbps.
> Any suggestions?
> Thanks
Try removing the signal booster from the setup and see if that makes a
difference.
I just did that - and then I tested. I initially got around 2000 kbps, and
thought that was the solution.
I've just done some more tests and now I'm in the range of 100 - 250 kbps
for download and 350 kbps for upload.
I've used DrTCP to adjust my RcvWin setting. It put it around 64000 (I have
WinXP). I'm still at 100 - 250 kbps for download speed, 350 kbps for
upload.
> kbps, and thought that was the solution.
> kbps for download and 350 kbps for upload.
> (I have
> upload.
Then the next step is to connect directly to the modem. If you still get
slow speed connected directly to the modem on all machines with new
cate5e cables, then call the ISP again. OTOH, if you find that just one
machine is slow directly connected to the modem (with a new cable),
then swap out the nic on that box.
