I built my own computer and everything was working fine. I got a 6200TC from a friend to use until i get a better one and have been using onboard graphics to run everything. I want to install the 6200 but i cant seem to figure out how to get it working. Ive uninstalled the drivers for the onboard graphics and the setup is for a Pci-e vc but whenever i put it in my motherboard nothing comes up on screen. Ive messed around with it trying different things but nothin will every come up. I dont think the VC is messed up cause my friend had been using it so maybe my pci-e slot is messed up. Now i have a bigger problem though. I tried changeing the VC selection in the like bios setup place from PQD/IDC(something like, my mobos book says that its for pci-e cards) to PCI. That didnt work so i kept it there and turned disabled internal graphics. So now i cant even get anything when i plug my monitor into my mobo. Does anyone know what i have to do to get it working with the onboard graphics again and make a suggestion of what i should do with my VC? Thanks
