Tom's Hardware > Forum > CPU & Components > CPUs > building a system and have a question
Forum CPU & Components : CPUs - building a system and have a question
If I build a system from the ground up (i.e. new mobo, new proc, new memory etc) and reuse a hard drive from an existing computer do I need to reformat and reinstall the HD or will the settings configure themselves.
I no that seems like a basic question....but, if I knewe the answer I wouldnt be asking.
Also, if I did need to reformat and reinstall os in new rig, is it possible to use an oem supplied winxp home reinstall disc (save from a dell dimension system) or would it require a non oem retail version.
One other thing, I plan on upgrading home ed. to xp pro as I have some unused licenses available for use.
Thank you in advance for the help!
Sponsored Links
You need to reformat if you are putting the drive into a new system.
Not 100% sure but my guess is that one of those "Rescue Discs" that comes with a PC that you buy at a store...... probably won't work and install a fresh copy of the operating system.
However, you probably do have a valid CD key for Windows and can download or borrow a CD from a friend. If you actually own a license, it wouldn't be morally wrong to get the software from other sources.
Reply to Mills
- 0 +
True, however, I wish to keep the dell installed oem xp home edition on my existing computer
The only thing I actually have a unused license for is xp pro upgrade.
But, I dont think its actually an upgrade cd, rather an upgrade license. So, Im not sure it would ever matter or Billy The Gates would find out :)
Trying to stay ethical, yet economical at the same time.
Thanks for all the replies. I will come up with something
Reply to JG
- 0 +
Quote :
It won't work. Dell's rescue CD (which has WinXP on it) checks to make sure you have a Dell BIOS. If you don't it won't work. You'll need to buy a retail copy of Pro or just get a pirated one like 50% of the enthusiast world does.
-mpjesse
Reply to mpjesse
There are 1148 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
