First Build: Slight Problem
MrMet
Ok, hooked up everything,
DFI lanparty nf4 UT
AMD dual core
2GB corsair RAM
550w PS
ATI-raedon All in wonder 800XL vid card...
etc..
Anways, hooked everything up, computer turns on, Processor fan spins, PS fan spins, vid card fan spins...
HOWEVER, IM GETTING NOTHING ON MY MONITOR!!!
HELP PLEASE!
G
Guest
Guest
Are you sure that you plugged the extra power cable into your mobo? (ATX power with extension AND the extra 4 pin cable)
Jason64
7
- check your vedio cable, replace one if you have one handy
- check your mobo handbook, make sure RAM in the right slot.
- unplug one of your RAM
- make sure CPU contact is right, CPU fan is properly attached
- try to use another vedio card
-unplug those indicator connectors (only leave the soft power one so you can still turn system on)
