Archived from groups: microsoft.public.windows.networking.wireless (
More info?)
knobs wrote:
> i get "you do not have permission to use this resource and not enough
> server
> space" when trying to access my network places. Networked printer
> works. What have I (not) done?
If this is the error message you are getting:
"Not enough server storage is available to process this command"
then try this solution by MVP Hans-Georg Michna:
"This error indicates that you are falling foul of the IRPStackSize bug.
The problem is on the machine you are attempting to connect to, not the
machine where you see the error message. On the computer you are
attempting to connect to, check the event viewer for an event ID 2011.
"Usual fix : You need to fix a parameter called IRPStackSize
"On the computer you are attempting to connect to, Set the IRPStackSize
back to the default (15 ). Perform the following steps:
1. Start regedit.
2. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters.
3. Double-click IRPStackSize (or if this registry setting doesn't
exist, create it with type DWORD and ensure the case is correct).
4. Change the base to decimal, set the value to 15, and click OK.
5. Reboot the computer.
"Norton AV is usual suspect for breaking it. There's a KB article about
this, too:
Antivirus Software May Cause Event ID 2011 (Q177078)
http://support.microsoft.com/default.aspx?scid=kb;EN-US;177078 "
HTH,
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
