Help with IP Printer add thorugh script
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.print (More info?)
Want to re-image a pc then add a TCP/IP printer. Below is what I have so far
but keeps adding the IP address as a local port instead of TCP/IP port.
Already tried changing the "oPort.PortType" to other numbers but didn't seem
to work. Any help would be extremely grateful as I'm very very new to
scripts. Thanks so much.
'******** Register prnadmin.dll file on client computer *******
Set WshShell = Wscript.CreateObject("Wscript.Shell")
WshShell.Run "regsvr32 /s \\s1avdc01\Tools\Prnadmin.dll",1,TRUE
'************** Create the port first *******************************
dim oPort
dim oMaster
set oPort = CreateObject("Port.Port.1")
set oMaster = CreateObject("PrintMaster.PrintMaster.1")
oPort.PortName = "IP_192.168.114.20"
oPort.PortType = 1
oMaster.PortAdd oPort
if Err <> 0 then
msgbox "There was an error creating the port."
end if
'************** Create the printer second ***************************
'Change MyPrinter to the name of the printer that you are adding.
'Change PrinterDriver to the name of the printer driver that you are adding.
dim oPrinter
set oPrinter = CreateObject("Printer.Printer.1")
oPrinter.PrinterName = "Test" ' name of the printer as it appears in the
Printers folder
oPrinter.DriverName = "HP LaserJet 2100" ' name that is referenced in
ntprint.inf
oPrinter.PortName = "IP_192.168.114.20" ' Specify a port name. Can also
point to LPT or COM port.
oMaster.PrinterAdd oPrinter
If Err <> 0 then
msgbox "There was an error creating the printer."
end if
msgbox "The script is finished."
gareth
79
Good one spamming the newsgroup....
Cos if you post the questions 3 times people will answer more quickly :p
"Steve Phillips" <StevePhillips@discussions.microsoft.com> wrote in message
news:1FB4D8A9-4626-49DF-84B1-36624CA39489@microsoft.com...
far
seem
> dim oPort
> dim oMaster
> oPort.PortType = 1
> if Err <> 0 then
> end if
adding.
> dim oPrinter
> Printers folder
> ntprint.inf
> If Err <> 0 then
> end if
G
Guest
Guest
I love people that show their ignorance. Maybe you should have questioned it
before running your mouth.
Microsoft kept reporting failure to post message & said to try again. I
tried three times and gave up, came back later and all three were posted.
Thanks for playing.
> far
> seem
> > dim oPort
> > dim oMaster
> > oPort.PortType = 1
> > if Err <> 0 then
> > end if
> adding.
> > dim oPrinter
> > Printers folder
> > ntprint.inf
> > If Err <> 0 then
> > end if
G
Guest
Guest
Just posted again & here is what I receive:
An error occurred while sending your post
We're sorry, but there was a problem with the system and your post was not
received. The error has been reported to Operations and will be investigated
as soon as possible. Please try again later.
> far
> seem
> > dim oPort
> > dim oMaster
> > oPort.PortType = 1
> > if Err <> 0 then
> > end if
> adding.
> > dim oPrinter
> > Printers folder
> > ntprint.inf
> > If Err <> 0 then
> > end if
G
Guest
Guest
Can this script fun on Windows NT?
news:65E8B6AC-5DC5-48C9-8512-09ABB306A4C4@microsoft.com...
investigated
:p
message
so
> > far
port.
didn't
> > seem
> > > dim oPort
> > > dim oMaster
> > > oPort.PortType = 1
> > > if Err <> 0 then
> > > end if
> > adding.
> > > dim oPrinter
the
> > > Printers folder
> > > ntprint.inf
also
> > > If Err <> 0 then
> > > end if
G
Guest
Guest
> post was not
> be investigated
> more quickly :p
>  > > Want to re-image a pc then add a TCP/IP printer.
> > far
>  > > but keeps adding the IP address as a local port
>  > > Already tried changing the "oPort.PortType" to other
> numbers but didn't
> > seem
>  > > to work. Any help would be extremely grateful as I'm
> very very new to
>  > > scripts. Thanks so much.
>  > > '******** Register prnadmin.dll file on client
> computer *******
>  > > Set WshShell = Wscript.CreateObject("Wscript.Shell")
>  > > WshShell.Run "regsvr32 /s
> \s1avdc01ToolsPrnadmin.dll",1,TRUE
>  > > '************** Create the port first
>  > > dim oPort
>  > > dim oMaster
>  > > set oPort = CreateObject("Port.Port.1")
>  > > set oMaster =
>  > > oPort.PortName = "IP_192.168.114.20"
>  > > oPort.PortType = 1
>  > > oMaster.PortAdd oPort
>  > > if Err <> 0 then
>  > > msgbox "There was an error creating the port."
>  > > end if
>  > > '************** Create the printer second
>  > > 'Change MyPrinter to the name of the printer that
> you are adding.
>  > > 'Change PrinterDriver to the name of the printer
> driver that you are
> > adding.
>  > > dim oPrinter
>  > > set oPrinter = CreateObject("Printer.Printer.1")
>  > > oPrinter.PrinterName = "Test" ' name of the printer
>  > > Printers folder
>  > > oPrinter.DriverName = "HP LaserJet 2100" ' name that
> is referenced in
>  > > ntprint.inf
>  > > oPrinter.PortName = "IP_192.168.114.20" ' Specify a
> port name. Can also
>  > > point to LPT or COM port.
>  > > oMaster.PrinterAdd oPrinter
>  > > If Err <> 0 then
>  > > msgbox "There was an error creating the printer."
>  > > end if
>  > > msgbox "The script is finished."
’"You will have to change the IP information"
’"also where prnadmin is located"
\\fl-msitest-orl\nde\Prnadmin.dll",1,TRUE
’************** Create the port first *****************************
’Port types
const kTcpRaw = 1, kTcpLPr = 2, kLocal = 3, kLocalDownLevel = 4,
kLprMon = 5, kHPdlc = 7
dim oPort
dim oMaster
oPort.PortName = "IP_10.1.1.21"
oPort.PortType = kTcpRaw
oPort.HostAddress = "10.1.1.21"
oPort.PortNumber = "9100"
if Err <> 0 then
end if
http://www.WindowsForumz.com/ This article was posted by author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.WindowsForumz.com/Print-Help-IP-er-add-thorugh-script-ftopict215798.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.WindowsForumz.com/eform.php?p=667747
