Hi guys and thnks for recieving me in your forum.
I have a Intel P4 3.0 GHZ prescott. With my case closed (without the side off) my CPU in idle stays at 45 and during CMR 2005 stays at 58-60 Celsius. And the case temperature after 30 min stays at 40 Celsius.
I was thinking that i want to drop the temp of my proc and of my case. But i noticed that my stock fan goes up in rpm only depending on the in case tmperature. When i had my case open i had problems with my proc going to 65-68 Celsius because the fan was not speening fast enough becasue the temperature of the system was arrownd 34-36 celsius.
My questions is... if i want to put a couple of fans in my case (intake and exaust) for better air circulation, wouldnt this make me have the same problem again? The one where my fan will not spin fast enough to cool the CPU? I say this because putting these fans i want to drop the temperatures but... what will be side efects??
I plan on buying another HTSK but when i'll win the lottery . until then i want to take care of my proc.
What do you think i should do? Is putting fans in my case and impooving air flow going to change the way my hetsink fan react and cool the CPU?
Thank you verry much!
