Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Using XP with DSL where, when and how can the DNS entries ..
Forum Wireless Networking : Wireless General Discussions - Using XP with DSL where, when and how can the DNS entries ..
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Using XP with DSL where, when and how can the DNS entries be changed from:
1. Obtain DNS server entries automatically
To enter them manual into:
2. Use these DNS server entries
First DNS server
Alternate DNS server
Can I borrow other DNS entries from MSN, IBM, Sprint, etc. ?
How can I find some DNS entries to borrow?
What is your best guess that makes BS DLS work and quit and connect and lose
connection since Katrina?
Thank you!
Sponsored Links
> First DNS server
DSL connection issues are completely unrelated to DNS issues. If it is
connection issues, I'd troubleshoot the connection issues first. Do you
have a DSL modem with access to the line status figures? If so, you want
line attenuation to be less than 60db, and the signal-noise ratio at least
9db to 10db. Greater than 60db attenuation, less than 6db snr and you will
suffer connection problems; only Bellsouth DSL techs can help you if line
troubles are evident.
I never was able to check my line stats before I installed a DSL splitter
at the NID (or MPOE, or demarc; the place where the telephone wire crosses
from the company to the premises). I did try to get "slick" when I
installed the splitter, and wound up with something called a, "bridge tap".
When I addressed the bridge tap issue I saw my snr rise from 6-7db to
12-14db; a good thing to see. My throughput speed is marginally better,
too; though it was nearly as good as I could expect on a 1536/384 line to
begin with.
Anyway, see if you can't improve the snr, at a minimum; maybe you don't
really have a DNS problem to begin with.
Alas, http://www.broadbandreports.com isn't responding right now. Nor is
the older alias, http://www.dslreports.com. There is a Bellsouth forum at
that site, and you should be able to get specific Bellsouth help there.
Norman
~Win dain a lotica, En vai tu ri, Si lo ta
~Fin dein a loluca, En dragu a sei lain
~Vi fa-ru les shutai am, En riga-lint
Reply to Anonymous
Galen fixed it.
http://www.artboy.org/2005/18/alternate-dns-servers
Yes you can use public DNS servers IIRC.
Galen
"N. Miller" <anonymous@discussions.microsoft.com> wrote in message
news:1vhwf3132xpq2$.dlg@discussions.microsoft.com...
>> from:
>> First DNS server
>> lose
> tap".
> begin with.
> Norman
Reply to Anonymous
There are 1069 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
