News
Apple Tops In Technical Support
Published on May 07, 2008
Cupertino (CA) - Apple in number one in technical support, according to the Consumer Reports magazine. Read more
AMD's CrossFireX Details Leak Out
Published on February 13, 2008
Some more information about AMD's CrossfireX architecture is leaking out, and it is about what you would expect. Up to four GPUs, mix and match to a degree, and one really bad part. Read more
Opera to integrate widgets, BitTorrent search in next browser
Published on February 06, 2006
Opera Software today announced that the next version 9 of its Opera browser will integrate a new extension that can access the BitTorrent search engine and can handle P2P downloads via its "Transfer Manager". A technical preview to be released on Tuesday will offer a first look on the BitTorrent integration. Read more
NEC's new multicore CPU can thread non-threaded applications
Published on December 19, 2005
Multicore is coming, no question about it. But today, the benefit of multicore processors is very limited as such CPUs need threaded applications to take advantage of the additional horsepower. NEC now says that it has developed a processor that automatically enables threading in any application - without the need to recompile or re-develop software. Read more
Latest Reviews & Articles
Best Video Cards For The Money: Nov '08
Published on November 10, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, though, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Power Supply Roundup: Part II
Published on November 07, 2008
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
Roundup: The Best Overclocking Software
Published on November 06, 2008
Interested in overclocking but not quite sure where to start? We round up some of our favorite software utilities for tweaking processors, memory, graphics, and chipsets. Read more
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
  Tom's Hardware Forums » CPU & Components » CPUs » Need Help on technical question...
Word :   Username :
Bottom
Author
 Thread : Need Help on technical question...
Profile: Honorary Master of THGC
More Information
What remembers previous overclock to allow boost in small steps?
Related Product
pat
Profile: Forum Veteran
More Information
Maybe it is because with small bump, you don't stress too much at the time and circuits can adjust and become more tolerant.
A big bump just put too much stress too fast and maybe the circuit have trouble to compensate that fast.
Think at you.. If you jump in hot water, you'll probably want to get out fast.. but if I put you in a big cauldron, and I heat it slowly, you'll be fine at Christmas meal...
More Information
So every time you turn off PC, you have to go through this process?
pat
More Information
No. because silicon would have been used to that now..
More Information
Oh, so it permanently changes the silicon?
pat
More Information
I guess.. Just like when you got a new car, you break in the engine..
Profile: addict
More Information
Here is an explication..no for the newbies....prepare to suffer...
In electricity, a conductor is a material like copper or silver which readily conducts electricity, while an insulator is the opposite: A material which doesn't conduct electricity well. In other words, a conductor has a very low resistance, and an insulator has a very high resistance. A semiconductor is a material that lies somewhere in between: It will sort of conduct electricity, but has a fair amount of resistance. Although not commonly cited as a "semiconductor", carbon exhibits this property: Electricity can conduct through carbon, but carbon does have a significant resistance, and much of the electrical energy will be lost as heat energy when it passes through carbon. Not coincidentally, carbon happens to be used frequently to make resistors.
The electrical conductivity of an element is related to how many valence electrons an atom of that element has. An atom is orbited by electrons, but not all of these electrons orbit in the same place; there are different layers of space surrounding the nucleus of an atom in which electrons can exist. Each of these spaces is called a shell. Usually, electrical engineers are most interested in the outermost shell of atoms. The outermost electron shell is called the valence shell, and electrons which exist in the valence shell are called valence electrons.
Once again, it is no coincidence that the semiconductor elements all have the same number of valence electrons: Four. The common semiconductor elements are carbon (C), silicon (Si), germanium (Ge), and antimony (Sb). All of these are "Group IV" elements, meaning they have four valence electrons.
When people talk about "semiconductors" in the PC era, they are usually talking about silicon. Silicon is the most common element on planet Earth (about 28% of all matter on the planet is silicon), so it's relatively easy to come by, but for chip-making purposes, it's not as cheap as you might expect: The silicon used in chips must be super-refined.
In any case, in a basic configuration of pure silicon, the silicon atoms actually form a very tidy grid. The silicon atoms share covalent bonds, which are chemical bonds formed when two atoms share two electrons with each other (i.e. one electron from one atom enters the valence shell of the other atom, and one electron from the other atom enters the valence shell of the first atom). Each silicon atom, then, is bonded to four others: One above it, one below it, one to the left, and one to the right. Each atom has eight electrons around it (because each bond adds an additional electron to the atom's valence shell).
What makes semiconductors like silicon particularly useful is how readily their conductivity can be changed by doping. On its own, silicon is only a mediocre conductor, but the conductivity of it can be changed quite significantly by doping, which is the process of embedding a very small amount of atoms of other elements within the silicon. Typically, only about one in a million silicon atoms are replaced with atoms of some other element, but that one in a million makes a surprisingly big difference.
Even more interesting is how doped silicon responds to the application of electrical voltage. It turns out that by applying different electric charges to doped silicon, you can actually change how conductive or resistive that silicon is. It is this effect which made the invention of the transistor possible.
So yes Pat is right the silicone and semi-condutors are 'proactive and reacts to the environement.
D'ont thanK me thank goes to
http://www.geocities.com/SiliconValley/2072/index.html
pat
More Information
Quote :
That's something you'll become familiar with ...
Profile: journeyman
More Information
Not knowing the first thing about the various theories of why you would want to boost your voltages in small increments I ask this question: In boosting in small increments can you be testing the system for weakness without causing harm? In other words will a weakness in the circuitry show up as instability with small increases rather than damage if steps are too large?
Profile: addict
More Information
Un jour je serai calif à la place du calif... (Iznogoud)
But for now i will keep an eye on you and keep on learning.... :roll:
(No problem i like silver medals you know)
:!: And the Gold goes to.... Pat :!:
pat
More Information
:wink:
Where in quebec are you??
Profile: addict
More Information
Look at this http://www.the12volt.com/ohm/ohmslaw.asp
The switching power supply try to keep an equilibrium defined by the ohm's law.
The temparature affects the conductivity of materials.
So if you push a 'micro tinny volt' to hard and the balance is lost you may
lock up or fry everything.... some have luck some d'ont...
Profile: addict
More Information
I am from downtown Quebec but i live in Val-Bélair.
pat
More Information
J'habite pres de grand-mere..
Profile: journeyman
More Information
Might it have something to do with this? http://en.wikipedia.org/wiki/Band_gap
Profile: addict
More Information
