G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.protocol.tcpip (More info?)
Here is the scenario:
On a Windows NT Domain network using TCP/IP with WINS and DHCP in a
Switched network. (Cisco and Extreme switches)
Currently the range of 172.16.200.1 - 172.16.200.38 is Static and given
out to various types of servers. The rest is DHCP with a subnet mask of
255.255.255.0
Recently, in an effort to increase the number of IP addresses available an
attempt was made to change the subnet mask to 255.255.240.0. And new IP
Addresses were given out. These look like 172.16.192.x to 172.16.192.xxx
In general things appeared to work but in effect they didn't. Anything
that had a 172.16.192.??? address couldn't see anything with a
172.16.200.??? address. Yet with the subnet mask we chose they should be
on the same network and should see each other fine.
Now this lack of functioning isn't complete. The lack of connectivity
will come and go. Say I find I have IP address 172.16.192.30 and the
server has IP address 172.16.200.31. Yet I can't ping the server. So I
release my IP address and renew it. Then I can ping the server again.
Yet if a wait a while I won't be able to ping the server. And if I wait a
while longer I can ping the server.
One other item in this mix is we have a Wide Area Network connected
through a Cisco Router. This router is set as the Default Gateway for all
machines.
Anyone have any ideas why these type of issues would be occuring?
Help.
255.255.255.0
machines.
Help.
