Hi,
I bought ASUS 7800 GTX TOP edition and I do have the very same problem, whenever and whichever latest 3D game I play, I experience what I can call a display corruption (almost like static, these gray dots or lines flcikering for a second and randomly appearing all over the place.). I did send my card back and the technician deemed is as working and fine (which is bs I can tell you) but I still have the same problem. I did install the latest drivers and such but nope it is still there. I also realized that it helps things little bit when I turn off FSAA. Moreover, it starts doing this 30 secs into the gameplay which makes me wonder if it is heat related issue?? But then again my card has even an a better cooler (artic) over the mainstream 7800 models, besides the temperature is usually around 70C during the games.
Here are my specs:
Mobo: ASUS A8N-E
*Motherboard Revision : 2.xx
*Motherboard BIOS Revision : 1006-002
AMD 4000 XP CPU
OCZ 2x512MB : PC 3200 ELDCPE-K DDR-SDRAM
ASUS Extreme 7800 GTX TOP Edition VGA card
Audigy 2 Sound Card
SeaGate 120 Gb and 160 GB Harddisks
ATI TV WOnder PRO
Enermax All in One 565P-VE Power Supply.
Plextor 716 DVD RW
HP 740 DVD-RW
Sony 52/32/52 CD-RW
Thanks in advance
LJ
Here are my specs:
Mobo: ASUS A8N-E
AMD 4000 XP CPU
Audigy 2 Sound Card
ATI TV WOnder PRO
Plextor 716 DVD RW
HP 740 DVD-RW
Sony 52/32/52 CD-RW
Thanks in advance
LJ
