Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Other Components > setting up a dual monitor system...
Forum CPU & Components : Other Components setting up a dual monitor system...
hi there!!!! i hate to ask but...how am i gonna be able to set up a dual monitor system???will i need appropriate software or something??my graphics card is MSI 7800NX 256Mb.thanks and...merry christmas!!
Reply to fiestaria
If your card has dual outputs, the driver software should come from card manufacturer or nVidia. It is included with drivers to support dual displays, you just have to configure drivers in the display options, and you got it.
Reply to RichPLS
- 0 +
At least it is that way with ATI
Reply to RichPLS
- 0 +
Here's a good link with pretty pictures on monitor (and dual monitor) installation and setup :
http://www.smartcomputing.com/Edit [...] .asp&guid=
It's called 'How To Install A Monitor', but if you scroll down about half way through the article, there is a section called : 'See Double: Set Up Dual Displays'.
HTH,
Cheers.
Reply to riksta
You don't need to use ATI's application for dual monitors unless you're mirroring them. ATI sets their cards up as primary and secondary displays so anyone can easily use windows Display Manager, clicking on the disabled monitor, then checking the box "Extend my desktop to this device", clicking apply, and dragging the monitor to the position you want it in relation to the original display.
For nVidia dual displays you have to use nVidia's application, which can be found by bringing up nVidia's custom configuration window. Right click on the screen, choose the nVidia display manager tab, and it brings up a custom box with all the options required to figure it out.
Reply to Crashman
That's not the proceedure nVidia uses. He has an nVidia card, for which modern nVidia drivers will configure as a single display in Windows. He needs to use the nVidia application, named nView, as seen HERE
Notice this is a separate menu, not the normal windows display manager setting you'd use with dual cards or an ATI dual output card.
Reply to Crashman
Your Graphics Card already supports dual monitors. You just have to set the
Multiple Monitors up in your display settings.
Here is a link to a great quick tutorial:
How to Setup Multiple Monitors
Also, here's a forum that is dedicated to Multiple Monitor Support:
http://forum.superpccomputers.com
Reply to rockstartrader
There are 1569 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What case should i get? Between these 3 with my build?
By amuffin, 5 hours ago:
They will all work, but I would grab the HAF 912. This is because I've owned the 912 and...
Best offers
Top experts
