Archived from groups: microsoft.public.windowsnt.protocol.tcpip (More info?)
Problem with TCPIP- won't work after reboot. Win 2000 Pro
uninstalling it in "Local Area Connection", rebooting, then reinstall
without reboot: works fine.
restart and TCPIP doesn't work. Must repeat above procedure.
netdiag doesn't show much- can't tell what's wrong.
The restart of TCPIP would seem to be at fault, but don't have a clue.
Bill Nash
Tip:
Using a E-mail program that is not susceptable to control by hackers makes sense to me... I use Agent: It's free and available from http://www.forteinc.com/agent/features.php Tip2:
Using a mail sort program that you can train to sort out the spam really reduces your workload, try POPFILE, it's free too! http://popfile.sourceforge.net/ Tip 3:
I use a program called "SPYBOT- Search & Destroy" to eliminate popups and adware, it's free and available from: http://www.safer-networking.org/ Tip 4:
Is your computer HACKED???!!! Find out at www.hackerwhacker.com/ or www.dshield.com -Free, of course!
