Tom's Hardware > Forum > CPU & Components > CPUs > WILL THIS CPU WORK IN MY MOBO...PLEASE HELP!
Forum CPU & Components : CPUs - WILL THIS CPU WORK IN MY MOBO...PLEASE HELP!
Looking to buy a dual core cpu namely a Opteron 165 or 170 for my rig but
will it work on my mobo...I have a Asus A8v deluxe K8T800pro chipset. Looked at Asus support web site a looked up suppoted cpu's it will support the X2 cpu's but didn't say anything on the optey's
I have the latest bios..1017 and currently the 1017 update info is not listed on their site. Does anybody know different?
thanks
Sponsored Links
s939 optys will work in s939 mobos.
Reply to Rugger
Rugger is right as always. AMD boards that are 939 pin support all 939 pin chips! Wish other chipmakers took the clue.
Reply to RichPLS
but will it be able to use both cores??
and thanks for the info 8)
Reply to jokersgrin
Yes, 100% compatible, but may need to update to current mobo's bios.
Reply to RichPLS
Thanks bro......knowing is half the battle :P
Reply to jokersgrin
There are 931 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
