Strange host name resolution failure, please help
I have been experiencing trouble accessing URLs via any browsers, however, I *can* access web sites directly via IP. A more complete list of fix attempts and diagnostic clues will follow.
I have found a temporary fix for my problem - namely, when I uninstall my NIC drivers, reboot, and allow Windows 7 to reinstall them, host name resolution seems to work, and browsing, software updates, and so on function normally. If I restart without first uninstalling my NIC driver, host name resolution fails again during the new session.
Relevant Computer specifications: Windows 7 Sp1, Comodo firewall, Avira AV, Gigabyte GA-MA790x-UD4P mobo, Phenom II 940
If more detail would be useful for any of the following, please ask.
-------------Fix attempts:
Router Powercycle
Modem Powercycle
connected directly to modem
turned off firewall
made sure proxies weren't running - proxy settings are clear in browser options
updated NIC drivers
cleared hosts file in /system32/drivers/etc
made sure UAC is activated
scanned for virii/malware using avira, malwarebytes, superantispyware, hijackthis, ckscanner
Ran following in command prompt: netsh int ip reset *then* netsh winsock reset *then* ipconfig /flushdns
Fixed registry via Glary Utilities
using Google's free DNS doesn't solve the issue
Have checked for DNS problems with my ISP
-------------Other diagnostics:
nslookup from console seems to work
ping from console does not work
ping from router seems to work
Comodo doesn't show unusual network activity
networkminer doesn't show unusual activity
WINS doesn't seem to work either; can't see other network computers
After a while, and asking for a retry, Steam is able to connect and see online players
Avira fails to update when prompted
Web browsing works proplerly from an Ubuntu 10.10 live CD
5 answers Last reply
More about strange host resolution failure help
  1. I suggest setting your DNS addresses to 8.8.8.8 and 8.8.4.4 as provided by Google to see if that helps.
    For more info, go to:
    http://code.google.com/speed/public-dns/
  2. I did that - it's on the bottom of my list of fix attempts. I've also checked in with my ISP - no DNS issues on their end, and using their DNS is no problem for this computer when I use my temporary fix of uninstalling NIC drivers, restarting, and reinstalling drivers.
    Sorry, I missed that when I read through the pile of tries. What browser(s) are you using?
  4. I've tried Firefox, IE, and Chrome.
  5. Sometimes when you have problems like this the best (easiest) course of action is to simply reinstall the operating system and it will tell you a lot if you still have the problem after the reinstall. However have you tried another network card? Even though you have tried the latest drivers for your card often network drivers for Windows 7 are a bit flaky and a common cause of problems.
Configuration Hostname Resolution Windows 7
