GPS problem
Forum Smartphones & PDAs : Windows Mobile - GPS problem
Archived from groups: microsoft.public.pocketpc (More info?)
I have an Asus A620 and have pocket streets on it. I can't get the GPS
function to work- it won't detect my Garmin etrex (I got a serial/gps cable
from PC-Mobile).
I'm using NMEA out. I've tried with/without a null modem adapter- I can't
tell whether one is needed (or how the PC-Mobile adapter is wired).
Has anybody any hints?
Sponsored Links
> cable from PC-Mobile).
> can't tell whether one is needed (or how the PC-Mobile adapter is
> wired).
If you have a serial - GPS cable and are connecting this to the A620's
serial cable then you need the null modem adapter. The Com Port should be
1. There are a number of small apps available to verify comms, check out
the downloads section of our site.
Darren Griffin
PocketGPSWorld - www.pocketgpsworld.com
The Premier GPS Resource for News, Reviews and Forums
Reply to Anonymous
"Darren Griffin - PocketGPS" <darren@pocketgpsworld.com> wrote in message
news:%23RkwDfSkEHA.1644@tk2msftngp13.phx.gbl...
> > wired).
> Darren Griffin
I realise that a null modem should be used- I've used GPS with a Psion PDA
for many years. This is connected via a GPS cable, null modem, then the
PC-Mobile one that goes from the cable to the pda.
I've tried reinstalling PocketStreets but no joy( used the software from the
Autoroute 2004 CD ). Is there a separate GPS program- I've seen something
mentioned but think that was older versions and can't see anything with
this.
I've just ran the GPS and main cable with my Psion and it works.
There are GPS menu options in PocketStreets that are greyed out and can't be
accessed - Always Show Position, and GPS Sensor (which is ticked). I can,
and do select COM1, but can't find anywhere in the PDA menus that allow
checking of port settings (speeds etc)- if it is possible.
I'll check through your site tomorrow- I'm on nightshift tonight. Are there
any other resources worth checking out?
Are there any other forums worth trying for help?
Thanks
Reply to Anonymous
> Psion PDA for many years. This is connected via a GPS cable, null
> modem, then the PC-Mobile one that goes from the cable to the pda.
> from the Autoroute 2004 CD ). Is there a separate GPS program- I've
> seen something mentioned but think that was older versions and can't
> see anything with this.
> can't be accessed - Always Show Position, and GPS Sensor (which is
> ticked). I can, and do select COM1, but can't find anywhere in the
> PDA menus that allow checking of port settings (speeds etc)- if it is
> possible.
> there any other resources worth checking out?
We have a thriving forums section and PC-Mobile have their own. If you get
the opportunity, register and post your problem and I'm sure we'll get you
sorted :)
> Thanks
Darren Griffin
Reply to Anonymous
Alan, if it is a cable from PC-Mobile designed to hook to an eTrex serial
cable, the PA6GS which has a male 9 pin connector that fits into the eTrex
serial cable (which has a female connector) then you do not need the null
modem. The input for Pocket Streets is fixed at 4800Bps. I believe the eTrex
uses that by default if you set NMEA as the output.
Did you note the power info at the PC-Mobile site?
To use GPS interface connecting to GPS, external power for Asus A620 must be
used as the electronic circuitry in the interface require power and the
internal power of Asus A620 is not enough to drive the electronics.
Sven, MS-MVP Mobile Devices
"AlanS" <news@remove.abyz.fslife.co.uk> wrote in message
news:ch7vg6$ao9$1@newsg4.svr.pol.co.uk...
> > > wired).
be
out
> > Darren Griffin
the
> this.
be
there
> Thanks
Reply to Anonymous
I've tried with and without the null modem adapter, and I have the Asus
powered by the external battery box that they recommend too. My etrex is set
for NMEA (it has a number of other outputs including Garmins own).
I think that the cable from PC-Mobile may be faulty- I've tried a continuity
tester and only 1 of the 3 connectors shows as connected through to the pda
connector. The three are common Data in, and data out, and the one connected
is pin 5 on the serial connector.
"Sven, MVP-Mobile Devices" <sejohannsen@hotmail.com> wrote in message
news:e$7tXIWkEHA.596@TK2MSFTNGP11.phx.gbl...
eTrex
be
message
GPS
serial/gps
> > > > wired).
should
> be
> out
> > > Darren Griffin
PDA
> the
something
> > this.
can't
> be
can,
> there
> > Thanks
Reply to Anonymous
I'd say give the guys at PC-Mobile a shout. They list asus@pc-mobile.net as
a contact specifically for Asus issues. They're in Hong Kong as you likely
know so there's a time lag, but they have been reasonably responsive in my
experience.
news:ch957p$6nr$6@news8.svr.pol.co.uk...
set
continuity
pda
connected
serial
eTrex
null
> eTrex
must
> be
> message
> GPS
> serial/gps
I
> > > > > wired).
A620's
> should
> > be
check
> > out
> > > > Darren Griffin
> PDA
the
from
> > the
> something
with
> > > this.
> can't
> > be
> can,
allow
> > there
> > > Thanks
Reply to Anonymous
Thanks. I'd ordered via ukorder2@pc-mobile.net and had emailed them, but no
response in over 24 hours, and it's now the weekend. I'll try a copy to the
address you give too.
news:%23XZL43ikEHA.1904@TK2MSFTNGP09.phx.gbl...
as
likely
> experience.
> set
> continuity
> pda
> connected
> serial
> eTrex
> null
> > eTrex
> must
> > be
the
> > message
the
> > GPS
> > serial/gps
adapter-
> I
is
> > > > > > wired).
> A620's
> > should
> > > be
> check
> > > out
> > > > > Darren Griffin
Psion
> > PDA
> the
> from
> > > the
> > something
> with
> > > > this.
> > can't
> > > be
> > can,
> allow
Are
> > > there
> > > > Thanks
Reply to Anonymous
> but no response in over 24 hours, and it's now the weekend. I'll try
> a copy to the address you give too.
Or post in our PC-Mobile Forum which is moderated by them
<http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewforum&f=49>
They have an excellent reputation for service so have no fear that they will
replace the cable.
Darren Griffin
Reply to Anonymous
news:OKmjWgkkEHA.3848@tk2msftngp13.phx.gbl...
will
> replace the cable.
> Darren Griffin
Thanks.
That would be 3 messages agent about this them in under 2 days, and at the
weekend too, plus this newsgroup would make 4! (1 to them in HK, 1 to the UK
already sent).
I don't really want to give the wrong impression (that I'm swamping them
with emails/postings all over the place!) so I'll hang on a few more days
before trying there, but thanks for the link. I'm really like to confirm if
it is actually faulty first, then how to get a working replacement
(preferably checked by them- someone/anyone - for operation first).
I would like to double check the pin continuity though- to know if the 3
Garmin data pins do show continuity on a working cable in this way (and
which pins connect to which if possible- but just the continuity would
confirm the status of my cable).
Many thanks for the link.
As an aside I'd like to recommend the battery box that they sell. It seems
smaller than I had expected, and is pretty neat and well built. There is a
screwhole to hold the top cover in place but no screw provided! It seems
solid enough without a screw in place, and it looks like a fairly small self
tapper would be needed. If the screw was in place I'd need the screwdriver
with me on travels to allow battery changes so it's probably best not used-
it doesn't seem to work well enough without the screw.
When connected and switched on it charges the internal battery (as if the
pda is connected to the mains), and one set of 4 x 1500 mAH NiMH batteries
have given 2 charges from around 60% up to now. NiMH AA batteries can be
found with over 2000 mAH now- I've seen 2150 mAH ones.
It seems as if it will be a good convenient alternative to a travel charger-
smaller and lighter too.
The cable seems quite short- but actually is about 12 inches long. A nice
and inexpensive accessory I certainly recommend, certainly not just for GPS
users but offers an easy, portable and inexpensive way to extend the pda's
battery life.
Reply to Anonymous
Perhaps I am missing something here. The Garmin cable to the PC is a simple
cable, no electronics in it. It should show continuity on each line/pin.
From what others have posted the ASUS A620 has a ttl to RS232 converter in
it. I would not expect it to show continuity between pins. (And I would not
be surprised if you happen to check between pins on the same connector (eg.
between pins on the RS232 connector) that you have blown the converter
within the ASUS A620 cable. The convert is protected when power up, but
applying power to pins on it when it is not power up is a very bad thing to
do, generally.
Here in the States I would need both a null modem adapter and also a gender
changer. Most PocketPCs have two versions of a serial cable. One designed
for ActiveSyncing which would require both the gender changer and null modem
adapter from Radio Shack. The other type, would be to add a serial
peripheral to the PocketPC (Which is harder to come by, and in my experience
generally short say 6 inches or so) and will have the same 9 pin connector
as on your PC.
David Hettel
Microsoft MVP Mobile Devices
This posting is provided "as is" with no warranties, and confers no rights.
You assume all risks for your use.
Handhelds, mobile: http://www.geekzone.co.nz
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
news:chcdhm$8dk$1@newsg2.svr.pol.co.uk...
> will
>> replace the cable.
>> Darren Griffin
> Thanks.
> UK
> already sent).
> if
> self
> used-
> charger-
> GPS
> battery life.
Reply to Anonymous
"David Hettel MS MVP - Mobile Devices" <dhettel@fuse.net> wrote in message
news:%23Ezr2NpkEHA.1348@TK2MSFTNGP15.phx.gbl...
simple
not
(eg.
Not likely if manufactured properly.
Don't forget, the RS-232 spec allows for voltage
swings of up to +/- 25VDC.
Most if not all DVMS use a 9V rectangular battery
as power source, hence the max. voltage that should
appear on the leads when it's set to any resistance scale
should not exceed that value.
Now, if you grabbed your Megger to do the checking, well...
It should be expected that some so-called "RS-232"
devices are manufactured on the ASSUMPTION that it will
NEVER ACTUALLY be hooked (as in a PC environment)
to an honest-to-God older RS-232 device like a TTY
where it'll see the higher voltages
allowed by the spec and fudge the circuitry
such that damaging it with a DVM may be possible.
ESD would be my choice of mechanism that destroyed
your cable (if it actually has been).
to
> do, generally.
gender
modem
experience
> as on your PC.
> David Hettel
rights.
message
> > will
> >> replace the cable.
> >> Darren Griffin
> > Thanks.
the
the
> > UK
> > already sent).
days
> > if
seems
a
> > self
screwdriver
> > used-
the
batteries
> > charger-
nice
> > GPS
pda's
> > battery life.
Reply to Anonymous
Why would that be different in Europe? Remember the PC-Mobile cable is
specifically designed to hook to a Garmin Data cable, as such the gender is
correct and the pinout is correct, for a direct connection. Sure, if you
are using the Garmin PC Cable and an Asus Serial Sync cable, you would need
the null modem to straighten out TX and RX, and likely the gender change
because both cables have female connectors, and the usual Null modem doesn't
change that. Incidentally if you buy a 9 pin null modem from PC-Mobile, you
get one with male connectors on both sides.
It does seem that the PC-Mobile Asus cable does have some electronics in it,
as the Dell X5 serial cable does, so checking for continuity from one end to
the other isn't going to tell much.
gender
> changer. >
> David Hettel
rights.
message
> > will
> >> replace the cable.
> >> Darren Griffin
> > Thanks.
the
the
> > UK
> > already sent).
days
> > if
seems
a
> > self
screwdriver
> > used-
the
batteries
> > charger-
nice
> > GPS
pda's
> > battery life.
Reply to Anonymous
Just speculating but if the Asus is like the Dell X5, then the 'serial'
capability at the bottom of the device is TTL logic, 0-5v (about). The Dell
produced Serial Sync cable has a TTL to RS232 converter built into the
cable. The cable then is expecting 0-5V on one side and -5 to +5 on the
other (about). The converter is powered from the Dell. You are right
though, that it would be unlikely that hitting even the TTL side with a
normal ohm-meter would damage it.
If you think about it, for a GPS all you need to do is get data from the GPS
into the PPC. That is data from the RS232 side into the TTL side. If the
1's and 0s are swinging +5 to -5 at the GPS and the receiver in the PPC
expects +5 for a 1 and 0v for a 0, it can actually work without a converter.
You won't get data transfer from the TTL to the RS232 though because the
RS232 side will never see a solid 0 (zero) because the TTL doesn't go
negative enough, or at all. (OK if it's negative mark that is all upside
down, but you get the idea). The serial sync cable that Dell sells is for
syncing, and therefore must be capable of doing data in both directions. May
or may not be the case with the Asus or PC-Mobile's cables.
"V Green" <vanceg@nowhere.net> wrote in message
news:%23GkD8lpkEHA.644@tk2msftngp13.phx.gbl...
> simple
in
> not
> (eg.
> to
> > do, generally.
> gender
designed
> modem
> experience
connector
> > as on your PC.
> > David Hettel
> rights.
> message
them,
try
they
> > > will
> > >> replace the cable.
> > >> Darren Griffin
> > > Thanks.
> the
> the
> > > UK
> > > already sent).
them
> days
confirm
> > > if
(and
> seems
is
> a
seems
small
> > > self
> screwdriver
> > > used-
> the
> batteries
be
> > > charger-
> nice
for
> > > GPS
> pda's
> > > battery life.
Reply to Anonymous
simple
There are only 4 pins on the Garmin unit. Therefore a MAXIMUM of 4 need to
be connected- more means more cost.
1 pin is for external power- it is specificaly not supported in the cable I
bought, and there is NO connector in the cable. That leaves the 3 connectors
I mentioned in an earlier post- a ground, data in, and data out.
The cable that then interfaces to my ppc connects to this cable, so only 3
pins are relevant, of which I can only detect continuity, or a connection,
to 1 of these pins.
not
(eg.
to
> do, generally.
The connection being tested is cable only. The A620 could be in China,
Australia or anywhere else- it's not relevant to the cable continuity test.
gender
modem
experience
> as on your PC.
The cable doesn't need a gender changer, but connection to my Psion
organiser did. (But that used a Psion serial connector which did data
transfers not only GPS data). The cable from PC-Mobile is specifically GPS
only. It needs no more than the 3 pin connections to fulfil its purpose.
wrt the null modem I have tried both ways- with and without- as the need for
one is not specifically stated on the pc-mobile site. It is a passive device
so no damage can be done, all that happens is data out and data in get
swapped around.
> David Hettel
rights.
message
> > will
> >> replace the cable.
> >> Darren Griffin
> > Thanks.
the
the
> > UK
> > already sent).
days
> > if
seems
a
> > self
screwdriver
> > used-
the
batteries
> > charger-
nice
> > GPS
pda's
> > battery life.
Reply to Anonymous
news:%23xibZEqkEHA.1048@tk2msftngp13.phx.gbl...
Dell
No damage has occured when measuring such devices in the past, this is a
resonably specified device well above entry level models. I would doubt any
relevance anyway- all it has been used on is the cable, *NOT* the pda- I'm
looking ror continuity (cable connections), so why would I need to go
anywhere near the Asus with the meter? It's pointless for this issue- cable
connections.
GPS
converter.
May
This is irrelevant to whether one pin is connected to another within an
irnterface cable?
Please read what was said- Only one of the 3 required pins shows to be
connected from one side of the pc-mobile cable to the other. The hint here
is the word cable, not pda, not Asus A620.
David Hettel is adding complication that isn't relevant. I isolated the
issue down to the cable or the Asus initially. The cable is easy to test-
just 3 wires. Only one is connected. It would seem this is the issue and any
work on the Asus is likely to be pointless?
If I had a cable where the 3 connections where made then it would be time to
look at the Asus, but I need a cable that works first?
message
> > simple
line/pin.
converter
> in
would
> > not
> > (eg.
thing
> > to
> > > do, generally.
> > gender
> designed
> > modem
> > experience
> connector
> > > as on your PC.
> > > David Hettel
> > rights.
> > message
> them,
> try
> they
> > > > will
> > > >> replace the cable.
> > > >> Darren Griffin
> > > > Thanks.
at
> > the
to
> > the
> > > > UK
> > > > already sent).
> them
> > days
> confirm
> > > > if
the
> 3
> (and
would
> > seems
There
> is
> > a
> seems
> small
> > > > self
> > screwdriver
not
> > > > used-
if
> > the
> > batteries
can
> be
> > > > charger-
> > nice
> for
> > > > GPS
> > pda's
> > > > battery life.
Reply to Anonymous
I guess you missed the point. The Dell cable I referred to has electronics
in the cable. It has a TTL to R3232 converter, IN THE CABLE. I speculated,
and I used the word 'speculated', that the Asus might be similar. In that
case you would not get continuity on the data pins, most likely just on the
ground. All I meant to bring up, is that there is some possibility that the
Pc-Mobile cable is more than two connectors and three wires, and testing it
with an ohmmeter may be counterproductive.
Good luck. I'm sure PC-Mobile will come through for you.
news:che8t2$ijr$4@news5.svr.pol.co.uk...
> Dell
any
cable
> connections.
> GPS
the
> converter.
upside
for
> May
> irnterface cable?
any
to
> message
> > > simple
> line/pin.
> converter
> > in
> would
> > > not
connector
> > > (eg.
converter
> thing
> > > to
> > > > do, generally.
> > > gender
> > designed
null
> > > modem
> > > experience
> > connector
> > > > as on your PC.
> > > > David Hettel
> > > rights.
> > > > Bluetooth guides:
> > > message
> > them,
I'll
> > try
that
> > they
> > > > > will
> > > > >> replace the cable.
> > > > >> Darren Griffin
> > > > > Thanks.
and
> at
> > > the
> to
> > > the
> > > > > UK
> > > > > already sent).
swamping
> > them
more
> > > days
> > confirm
> > > > > if
first).
> the
> > 3
> > (and
> would
It
> > > seems
> There
> > is
> > > a
> > seems
> > small
> > > > > self
> > > screwdriver
> not
> > > > > used-
> if
> > > the
> > > batteries
> can
> > be
travel
> > > > > charger-
A
> > > nice
just
> > for
> > > > > GPS
the
> > > pda's
> > > > > battery life.
Reply to Anonymous
Thanks. I'll post back when I find a solution.
I wouldn't expect any devices in the cable but I'll let you know if your
thoughts are correct, but I have doubts as there is no power supply to the
cable, just ground, data in and data out.
news:OY6CPM7kEHA.3720@TK2MSFTNGP12.phx.gbl...
the
the
it
'serial'
> > Dell
the
a
> any
I'm
> cable
> > connections.
the
> > GPS
> the
PPC
> > converter.
the
> upside
> for
directions.
> > May
> > irnterface cable?
here
test-
> any
time
> to
> > message
a
> > > > simple
> > line/pin.
> > converter
> > > in
> > would
> > > > not
> connector
> > > > (eg.
> converter
> > thing
> > > > to
> > > > > do, generally.
a
> > > > gender
> > > designed
> null
> > > > modem
> > > > experience
> > > connector
> > > > > as on your PC.
> > > > > David Hettel
no
> > > > rights.
> > > > > Bluetooth guides:
in
> > > > message
emailed
> > > them,
> I'll
> > > try
> that
> > > they
> > > > > > will
> > > > > >> replace the cable.
> > > > > >> Darren Griffin
> > > > > > Thanks.
> and
> > at
> > > > the
> > to
> > > > the
> > > > > > UK
> > > > > > already sent).
> swamping
> > > them
> more
> > > > days
> > > confirm
> > > > > > if
replacement
> first).
if
> > the
> > > 3
way
> > > (and
> > would
sell.
> It
> > > > seems
> > There
> > > is
> > > > a
It
> > > seems
fairly
> > > small
> > > > > > self
> > > > screwdriver
best
> > not
> > > > > > used-
(as
> > if
> > > > the
> > > > batteries
batteries
> > can
> > > be
> travel
> > > > > > charger-
long.
> A
> > > > nice
> just
> > > for
> > > > > > GPS
> the
> > > > pda's
> > > > > > battery life.
Reply to Anonymous
I have to say first impressions have not impressed.
Sales have sent me some questions, and not even attempted to answer my
questions, and giving the impression of totally ignoring the information I
have given them.
news:chgunk$h0g$1@newsg3.svr.pol.co.uk...
electronics
speculated,
that
> the
> the
> it
> 'serial'
The
> > > Dell
the
> the
right
with
> a
a
doubt
> > any
> I'm
> > cable
> > > connections.
> the
> > > GPS
If
> > the
> PPC
> > > converter.
> the
go
> > upside
is
> > for
> directions.
> > > May
an
> > > irnterface cable?
> here
the
> test-
and
> > any
> time
> > to
> > > message
is
> a
> > > > > simple
> > > line/pin.
> > > converter
> > > > in
I
> > > would
> > > > > not
> > connector
> > > > > (eg.
> > converter
bad
> > > thing
> > > > > to
> > > > > > do, generally.
also
> a
> > > > > gender
> > > > designed
and
> > null
> > > > > modem
serial
my
> > > > > experience
> > > > connector
> > > > > > as on your PC.
> > > > > > David Hettel
> no
> > > > > rights.
> > > > > > Bluetooth guides:
> in
> > > > > message
> emailed
> > > > them,
> > I'll
> > > > try
> > that
> > > > they
> > > > > > > will
> > > > > > >> replace the cable.
> > > > > > >> Darren Griffin
> > > > > > > Thanks.
days,
> > and
> > > at
> > > > > the
HK,
> 1
> > > to
> > > > > the
> > > > > > > UK
> > > > > > > already sent).
> > swamping
> > > > them
few
> > more
> > > > > days
to
> > > > confirm
> > > > > > > if
> replacement
> > first).
know
> if
> > > the
> > > > 3
> way
> > > > (and
continuity
> > > would
> sell.
> > It
> > > > > seems
built.
> > > There
> > > > is
> > > > > a
provided!
> It
> > > > seems
> fairly
> > > > small
> > > > > > > self
> > > > > screwdriver
> best
> > > not
> > > > > > > used-
> (as
> > > if
> > > > > the
NiMH
> > > > > batteries
> batteries
> > > can
> > > > be
> > travel
> > > > > > > charger-
> long.
> > A
> > > > > nice
> > just
> > > > for
> > > > > > > GPS
extend
> > the
> > > > > pda's
> > > > > > > battery life.
Reply to Anonymous
Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > GPS problem
There are 1003 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
