Tom's Hardware > Forum > Overclocking > Motherboards > Boot Problems ....PLEASE HELP
Forum Overclocking : Motherboards - Boot Problems ....PLEASE HELP
Alright heres whats going on.
First my raid fell apart...with a BSOD saying disk error
So I went to my spare ...and IDE that I used to load windows and transfer to my raid for performance.....it did the same thing BSOD with disk errors....and started dumping the memory on screen.
I disable the raid controller and started to zero out all hard drives, thing that I had a virus or something. Did that and started to load windows...everything went fine, loaded all updates for windows and the last thing I did was download and install new via drivers and then BSOD..again....now I can't even get to windows desktop.
It will start to load then the computer will reboot again and again.
I need your input here because I'm stuck
spec's
amd 64 3000 venice
asus A8V deluxe mobo....latest bios update 1017
asus n 6600gt
2 gig ram... 512x4 of geil ddr400
2 sata maxtor 120 gig..for raid
1 maxtor ide 20gig
thanks for any help and or wisdom you can give me :evil:
Sponsored Links
My guess would be those via chipset drivers are your problem and/or your raid controler. Just run with an older version of the driver or the default windows drivers and see if that fixes your problem.
Reply to endorphine44
There are 681 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
