G
Guest
Guest
Archived from groups: comp.security.firewalls,microsoft.public.windowsnt.registry (More info?)
I tried to install Sygate Personal Firewall on NT4(sp6). The installation
failed. No idea why, because (I'm guessing here) Sygate seems to have
blocked a logfile Dr Watson claimed it was creating. Whatever happened, the
error log wasn't created.
When I tried to uninstall Sygate, I discovered the following:
- Double clicking a program icon on the desktop opens the program in
Notepad.
- Trying to run a program via the start button menus does the same.
- Start|Run works fine.
- Right clicking a desktop icon and selecting "open" works fine.
- I can get into Control Panel, but anything I click in there loads into
Notepad. *
- .bat files run fine from the desktop. I haven't tested .cmd yet.
- Files associated with programs appear to work normally from the desktop
(the connected app runs and loads the file).
* Because of the Control Panel problem, I couldn't use "install/remove
programs", and no other method of uninstalling was available. Result: I had
to do a manual uninstall to get rid of Sygate.
There are a few remnants Regedit says it can't delete (keys under the name
LEGACY_SYGATE), and undoubtedly a few things I've missed. Does anyone know
if these registry entries could be causing the .exe problem, and if so, how
can I get rid of them? If they are not the cause, what could be, and how
might I fix it?
I would just tear my hair out, but the reason I want a firewall installed is
that I already tore it out while combatting a heap of viruses and other junk
that got onto my hard drives a couple of weeks ago
TIA.
Regards,
Crazy.
http://web.ukonline.co.uk/crazy.aljy
Notepad.
Notepad. *
might I fix it?
TIA.
Regards,
Crazy.
